7.3 Water Pump Replacement - Ford Truck Enthusiasts Forums
Old 04-15-2009, 07:00 PM
usherac21 usherac21 is offline
usherac21 is starting off with a positive reputation.
Does anyone have a link for the instructions on how to change a water pump on these engines?
Old 04-15-2009, 07:03 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Here you go Diesel-Central.com the technical source for Diesel Truck information, Truck Pulling, and Drag Racing
I just did this 2 weeks ago. Follow the instructions exactly and you'll have no problems at all.
Old 04-15-2009, 07:06 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.vettdvr is gaining momentum as a positive member of FTE.
No link but some useful info. PM me your email and I will send pics.
7.3 Ford Diesel water pump change information
<o></o>
Water Pump used<o></o>
<o></o>
Autozone DWP-9128 UPC 6 11176 00692 7<o></o>
<o></o>
Bolts on thermostat 6MM 1MM pitch about 25 mm long Hardened. Note they have locktite hit head with
Hammer to break seal before attempting to remove or bolts will break
<o></o>
O Ring seal needed on bottom pump extension. O ring seal used on thermostat top housing
<o></o>
Wrench for Fan is 1 7/8 “ or 48 MM
Wrench for holding pulley is 54 MM. Must use both wrenches to remove fan. This is the most difficult
part of the pump change OEM part # 27141,, but not Ford OEM is the brand name.
Replace all hoses, belts, and check idler/tensioner pulleys,thermostat
Old 04-15-2009, 07:57 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
It was mentioned that the torque was high on the bolts listed on that site. “Blackjeep” noticed error. Don't snap'em.
The links don't work(lost in the conversion) but i attached a page out of the manual.
Old 04-15-2009, 08:04 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Water Pump change video on youtube CLICK HERE
Old 04-16-2009, 08:47 AM
Thanks for all the responses. How long should this repair take to to complete? Keep in mind that I am not a mechanic, and I have only average mechanical skills.
Old 04-16-2009, 10:03 AM
gofast51004's Avatar
gofast51004 gofast51004 is offline
gofast51004 is starting off with a positive reputation.
Quote:
I just did mine a couple weeks ago....took about 3.5 hrs, but that was with a couple beers thrown in there. Real easy too.
Old 04-16-2009, 10:06 AM
vettdvr's Avatar
Quote:
Good video a few pointers though:
1) The video called out 2 people special wrench (I covered this also) and a pipe wrench.
I did this with the special wrench only and 1 person. What I added was !@#$!@#%$@#$^^$ and it came of easily.
2) I removed the hoses from the attachable necks and removed them with the water pump.
3) I did not remove the hose neck at the thermostat prior to removing the water pump.
NOTE: I found on the first bolt it snapped off easily. The remaining 2 smacking with ball peen round end of hammer before attempting to remove prevented breaking. Don't know why they stuck. But mine did not come out as easily as the video.
4) I used the tinnnnest drop of super glue to hold the water pump gasket in place. Think pin head size. to prevent the gasket from dropping out during installation.
5) Check all pulley/bearings
6) Replace all hoses and please buy the upgraded hose that goes around the belt vs through it. This will make you life easier next time.
7) I also reused the thermostat due to not having the correct one to install. I would recommend buy the factory part for the 7.3 thermostat.
Old 04-16-2009, 10:21 AM
megawatt00's Avatar
I used a visegrip style chain wrench 19" IIRC to hold the pulley, and a small pipe wrench on the nut. It is about a 3 hour job.
Old 04-16-2009, 12:18 PM
PaysonPSD's Avatar
I used Syl-Glide silicone lubricant from Napa on the o-rings and the pump gasket. The Syl-Glide's tackiness held the pump gasket in place.
Old 04-16-2009, 03:50 PM
vettdvr's Avatar
Good suggestion! my Napa was 20 miles away and I was working alone.
Old 04-16-2009, 05:37 PM
JMac444 JMac444 is offline
JMac444 is starting off with a positive reputation.
Just a thought if you havent gotten a water pump id go with the Napa new tru flow pump part # TFW 45000. Its the best ive come by and its a one piece design so no more leaking lower neck. For what a t-stat and gasket cost change them! http://www.napaonline.com/NOLPPSE/(S(wgeyqgio430buk55ahm2fn55))/Detail.aspx?R=TFW45000_0144865560
Water pump on or Water pump off Sensai? 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 1 09-26-2016 06:50 PM
1971 351w water pump style Carmax 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-25-2015 08:02 PM
replace water pump Viper03 1987 - 1996 F150 & Larger F-Series Trucks 7 10-14-2014 01:43 PM
Counterclockwise 390 water pump arcticatdan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 01-31-2014 11:04 AM
Need water pump part.# 02 Ranger B 3000 Ranger & B-Series 1 03-12-2009 10:18 PM
Tags
2000, 73, changing, diesel, ford, oem, pump, remove, repair, replace, replacement, tfw, tfw45000, thermostat, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
