Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-14-2009, 04:09 PM
Redranger03 Redranger03 is offline
Redranger03 is starting off with a positive reputation.
Cabin Air Filter, 2009 Escape...
Has anyone installed a cabin air filter on the "newer" Escape? It is my understanding, that they can be installed by the owner as they do not come equipped with a filter from the factory.
If so, what are the supplier's part numbers.
  #2 (permalink)
Old 04-15-2009, 08:36 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
No numbers for you but I read somewhere that the filter gets plugged up quickly and air flow is reduced.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #3 (permalink)
Old 04-15-2009, 01:46 PM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Exiled from the club.
Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold
Even a clean filter cuts air flow fairly substantially. I'll probably leave them out next time I check those that I installed in both of my Escapes. The cabin filters do cut down on pollen and dust inside the car but ONLY if you never drive with the windows open.
As far as the install, piece of cake in the '05 and '06 models. Take the plastic cover at the base of the hood (passenger side) and drop in the filter. Ten or 15 minutes at most. Maybe a little longer the first time.
None of the Fords that I have bought over the last 10 years have come with a cabin air filter from the factory.
__________________
Ray
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
  #4 (permalink)
Old 04-15-2009, 04:32 PM
Ok, thanks...my wife has problems with allergies, thought it might help...
  #5 (permalink)
Old 04-15-2009, 07:46 PM
JFUSION JFUSION is offline
JFUSION is starting off with a positive reputation.
when you see how black the used filters get after such a short time it seems like a good idea.
  #6 (permalink)
Old 04-20-2009, 01:36 PM
twolostminds twolostminds is offline
twolostminds is starting off with a positive reputation.
2009 Ford Esape Cabin Air Filter
Fram - CA10170
Motorcraft OEM - FA1772
Purolator - A25567
K&N - 33-2347
Wix - 49187
NAPA - FIL 9187
Installation Instructions:
1. Raise hood.
2. Remove the 7 plastic clips that run along the forward edge of the cowl. Use a philips head screwdriver and push up in the middle from the bottom. Remove the screw and the clip.
3. Pry up the forward edge of the plastic cowl piece on the passenger side. Mine was stuck down with a sticky foam strip which remained attached to the plastic cowl piece. This is where my wife assisted by holding the cowl piece up out of the way so I could raise the lid to the air box.
4. The lid to the air box has 2 plastic clips on the forward edge holding it in place. Gently pry the tab forward (toward the front of the vehicle) while lifting the top. I found releasing the outboard clip first worked best (it's also the most visible of the 2). I did not remove the lid, just lifted it up enough to get the filter in place inside the air box.
5. Install the air filter in place, since it is such a funny shape it will only go in one way which is obvious. As stated here and other places I researched, the filter does not fit perfectly. It is the right shape it just seems to be a little too big. I had to push the edges down into place in order to get a decent seal which slightly distorted the filter. It should work fine though.
Same filter and instructions for both the 09 Escape & Escape Hybrid.
Found on www.GreenHybrid.com
  #7 (permalink)
Old 04-21-2009, 07:35 AM
Thanks for the info, twolostminds.
__________________
Socialism is great...until the wealthy run out of money. ~Margaret Thatcher~
  #8 (permalink)
Old 06-21-2009, 03:43 AM
jbracefan1977 jbracefan1977 is offline
jbracefan1977 is starting off with a positive reputation.
hey, I have the same K&N also and love it, I could not find a good deal on ebay so I found a discount coupon here: K&N 33-2347, or you can try one of the vendors on the forum here, you can usually find a good deal that way as well. This was very easy to install and I love it.
  #9 (permalink)
Old 06-30-2009, 10:39 PM
just curious if these filters get wet from being under the cowl ?, or do they stay relatively dry. I would think they might start to smell if they get any kind of moisture in them. Any info would be helpful, thanks.
Tags
08 , 2006 , 2008 , 2009 , air , cabin , escape , filter , find , ford , installation , installing , instructions , location , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
