NP205 PTO Unit - Ford Truck Enthusiasts Forums
NP205 PTO Unit
Old 04-14-2009, 01:02 PM
Screamin T/A Screamin T/A is offline
Screamin T/A is starting off with a positive reputation.
NP205 PTO Unit
Hello all, I was wondering if any NP205 pto unit will bolt up to the 205 on my '79 f-250? I have a lead on a spicer unit that came from a '78 dodge powerwagon np205, but am not sure because I believe the dodge has a passenger side drop, and my truck has a drivers side drop for the front driveshaft. I want to run a pto winch out the rear of my truck with the pto. I have a pto for my NP435, but just recently realized it is only one speed in the directon of the crank, so therefore I will not be able to power out the winch cable. This is no good to me. I want to get one for the transfer so that I can use the tranny gears to control the winch direction...let me know if the dodge unit will work, and also if you see any flaws in my setup...thanks
Also, I have heard that I can just switch the gears in my current unit to mesh with the 205, any info on this? thanks.
anyone heard of a PTO winch? jerry73 1973 - 1979 F-100 & Larger F-Series Trucks 16 01-10-2014 02:04 PM
Winch Confusion! Screamin T/A Offroad & 4x4 0 05-20-2009 09:26 PM
NP205 PTO unit Screamin T/A Offroad & 4x4 1 04-15-2009 08:38 PM
NP 435 PTO Question n9lhm Clutch, Transmission, Differential, Axle & Transfer Case 0 06-27-2005 03:33 PM
PTO...winch georgiafordman78 Offroad & 4x4 5 12-06-2001 02:09 AM
Tags
2000, 205, 79, case, ford, np, np205, power, process, pto, transfer, transfercase, truck, unit, winch, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
