06 exp transfer case shift
My wonderful 06 exp will not shift into 4L for sure and I am certain also 4H.
I move the switch in 4L as soon as I let go of the brake after I place gear selector in D I get the info center informing me to put foot on brake and neutral to engage 4L, did that already.
It's not in 4 L I can feel it not in low range, seems to be a common problem with these, no error codes so I take it shift motor is on permanent vacation who makes a good quality replacement new or rebuilt other than FORD?
many thanks,
-T
To FORD if you read these Forums: I like my 78 bronc, 93 F350 and 76 F100 4x4's much better. Just pull a manual lever and lock hubs deal is nice insurance to know I don't get stuck in the woods in 2 wheel drive when vehicle has 4 wheel drive and some cheap made electric piece just happen to break ( ok 3 wheel drive, all mine have locker or LS in the rear at minimum, F350 and F100 have lockers front and rear)
many thanks,
-T
many thanks,
-T
many thanks,
-T
Transfer case
Integrated wheel ends (IWE)
IWE solenoid
4x4 module (PCM)
Front axle assembly
Mode select switch (MSS)
Circuit 682 DB/WH)
Circuit 780 (DB)
Circuit 704 (DG/LG)
CJ13 Fuse 115 (30A)
The IWE Integrated wheel ends are prone to not engaging properly. ALLDATAdiy.com has indivdual tests for all of these symptoms in order to properly diagnose your Ford Expedition.
ok i did this
https://www.ford-trucks.com/tsb/full...hp?tsb=06-8-15
front "hubs" engage now in auto auto traction and 4H, I tested it on a wet hill, but no 4low.
Any other parts, sensor,,,,????
Ak Ford Man
11-21-2010 05:35 PM
wildcat99
35
03-26-2004 09:17 PM
