TorqShift Transmission - Information and Troubleshooting
#61
I have a question on trans temps. Right now all I have is the "idiot light" gage, and it shows "operating" temperatures very quickly, even when cold outside. I just read in another forum that tex25025 said that his trans once showed 160F within about 5 minutes, and that it shows something is wrong. I am just looking for a little insight as to what problems/things I need to look for, and does this mean I may need a new trany soon.
#63
#64
This is in "post #3" of this thread, but I thought I would repeat it ..............
The "Factory" transmission temp gauge, it is a glorified "idiot" light as its response is severely dampened. The panel gage will show the temp as fully warmed up at 50 *F. Between 100-220F the needle will remain in the same position on the gauge. At 230F it will move up slightly to the middle of the normal range. At 250F it will move to Yellow. The gage moves to red at 280. This is supported on page 36 of the OBDII Theory and Operations manual. The tow/haul light will flash at 275.
#66
Whats up guys. Heres the deal. I picked up my '05 6.0 from the dealer after they installed a new turbo, oil cooler, egr cooler, and radiator. As i was driving home,(not even 10 miles) the tow haul light started flashing and everytime it would try to shift into 3rd(i think) it would literaly LOCK down like you slammed on the brakes. Once you slowed down/stopped it would "unlock" again until 3rd. What do you think?
Here is a list of codes the ford house just gave me..P0700, P0772, and P2704 hope that helps.
THANKS guys, Verlin
THANKS guys, Verlin
#67
#68
#70
Brickie's great link was "broken", so I did some searching and I think the link below is to the article he found:
http://atsg.com//dyndata/articles/pd...0Torqshift.pdf
Lots of good info in it!
#71
#72
I just had tranny fluid come out my dipstick (maybe a quart) after a very intense 30 minute (6-9% grade) pull in 85 degree heat pulling a 10k 5th wheel.
Gauge was reading 2 line widths below 'yellow'.
Could something inside have overheated causing this at a relatively low temp?
Next day ran great and never heated again but only 70 degrees outside temp.
Enjoying your info- love learning this stuff!!!
#73
#74
Is fluid coming out the dipstick the 'weakest link'?
IE before something else is damaged???
I read there is a pressure release valve- could that have stuck when it got hot?
#75
