Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 04-16-2009, 07:49 PM
04F-250mark's Avatar
04F-250mark 04F-250mark is offline
2004 Ford F-250
04F-250mark is starting off with a positive reputation.
Good god man! I knew you were full of knowledge, but da?mmit you are good
rep's to ya!!
__________________
2004 F-250,CREW CAB,FX4,6.0PSD,285-70-16 KUMHO ROAD VENTURE AT,TOURQESHIFT AUTO,ZOODAD MOD,Dieselsite Coolant Filter,ARP STUDS,4" TURBO-BACK MAGNAFLOW you've got to love that sound!! (whistle)
  #17 (permalink)
Old 04-16-2009, 07:51 PM
2004 Ford F-250
I tried but I need to spread some.
__________________
  #18 (permalink)
Old 04-16-2009, 08:39 PM
liv's Avatar
liv liv is offline
liv is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by bismic View Post
I hope to make this a thread that contains an extensive amount of information on the TorShift transmission. I am sure it will be several posts. All other information is welcome.
I will begin w/ the Broadcast messages and the TSB's:
Damnit Mark, do I always have to fix your mistakes?
I hope to make this a thread that contains an extensive amount of information on the TorqShift transmission. I am sure it will be several posts. All other information is welcome.
__________________
-06 s60 R
  #19 (permalink)
Old 04-16-2009, 08:52 PM
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Quote:
Liv - check your "User cp" info ..........
(for humor value)
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #20 (permalink)
Old 04-16-2009, 08:56 PM
liv's Avatar
liv liv is offline
Hahahaha
Thanks bud that makes me feel special.
__________________
-06 s60 R
  #21 (permalink)
Old 04-21-2009, 08:38 PM
bismic's Avatar
Here is an informative link on the TorqShift - supplied to me by Brickie.
Find a post of his and give him some rep points for me!
Ford 5R110W Torqshift
__________________
Mark
  #22 (permalink)
Old 04-21-2009, 10:32 PM
brickie's Avatar
brickie brickie is offline
brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE.
Mark hope you don't mind this added.This is one of your better works, great info my friend !Ford 5R110W TorqshiftSorry I didn't see you caught it all ready. Great to have you here sharing all the goods.
__________________
Tony 03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
  #23 (permalink)
Old 04-27-2009, 09:23 PM
brickie's Avatar
Cut away of Torqshift.This is a pretty cool view of the tranny. Ford Genuine Parts Torqshift 5 Speed Automatic Transmission - Cutaway Creations
__________________
  #24 (permalink)
Old 04-27-2009, 10:01 PM
Mulepick's Avatar
Mulepick Mulepick is offline
Mulepick is starting off with a positive reputation.
Good idea for a single tranny data locale and great info to start it out. Green square to follow.
My previous vehicle was a 2004 4Runner V-8 that I installed a trans temp gauge on. The sensor was located on the "hot" side of the external heat exchanger. Most of the time, the trans fluid is at ambient air temp. A very good trans mechanic once told me that the fluid is routed through the radiator not for cooling but preheating.
I mention this in contrast to what we see on the dash trans temp gauge which gives the impression of much warmer (and sometimes much cooler) temps than one would imagine.
Bob
__________________
2006 F-250 crew cab, SWB, SRW, PSD, Lariat/FX4, A/T, ARP studs, ISSPRO Pyro and Trans temp,Fumoto,
Mobil 1, BFG Radial T/A 285/70-17s,Helwig rear sway bar,Ride rite air bags/onboard compressor, coolant filter
2004 Lance 820 camper
  #25 (permalink)
Old 04-27-2009, 10:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
Quote:
Your very good trans mechanic is wrong. The fluid is routed through the radiator transmission cooler is there ONLY to cool the fluid. It never preheats the fluid.
I've measured temperatures in and out of the trans cooler and in and out of the radiator at ambient temperatures from -40F to +115F. The ATF is NEVER heated by the in tank cooler.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #26 (permalink)
Old 04-27-2009, 10:42 PM
Mulepick's Avatar
We're talking about the same radiator/heat exchanger, right? I'm talking about, on my previous vehicle, transmission fluid is routed through the engine coolant radiator before it goes through its own transmission heat exchanger (cooler). It's this coolant radiator (usually referred to as "the radiator") that I refer to. This radiator starts heating up as soon as you start the engine and will, over time, warm up to normal op temps at idle. Trans fluid is circulating through this radiator the whole time with no trans work being done. This is the preheating I refer to.
I don't consider myself dumb or inexperienced but I can't think of a single subject that I feel comfortable using words like "never" or "always" about, particularly when there is a very real possibility I didn't understand the comment.
Your rep is exemplary!
Bob
__________________
  #27 (permalink)
Old 04-28-2009, 02:32 AM
cartmanea cartmanea is online now
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
Mulepick, read Mark's sig
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #28 (permalink)
Old 04-28-2009, 04:10 AM
Mulepick's Avatar
I appreciate his reputation and the knowledge/experience suggested in his sig. None of this is lost on me when I was astounded by his reply. What has me stumped is resolving his significant expertise with basic laws of thermo dynamics. Both are compelling to say the least.
I believe there is a misunderstanding on what fluids/exchangers I'm talking about. At its simplest, however, I'm pretty sure that as I run a pipe of 72 degree fluid through a bucket of 150 degree fluid I'm going to see a boost in temp. Now, things may have changed since I went to engineering school, and I know a civil engineer is not an automatic transmission engineer, but I'm still going to side with Ike Newton, Carnot, and Gibbs on this.
Bob
__________________
  #29 (permalink)
Old 04-28-2009, 08:34 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
One thing about Mark's statement makes me agree with him. The engine has a t-stat that restricts flow thru the readiator till a pre-set temp. is reached. Most tranny fluid flows immediately thru the rad. Since the tranny is instantly, almost, heating its fluid thru friction driving the vehicle, I think its fluid under most circumstances would need cooling before the radiator is even up to the t-stat temp.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #30 (permalink)
Old 04-28-2009, 09:35 AM
The part that you're forgetting is that the engine radiator is there to cool the engine's coolant. By the time that coolant has made it from the end of the radiator where it entered at engine temperature to the side where it leaves to go back to the engine it has cooled considerably. That's what a radiator does. I've measured as much as 100F drop in coolant temperature from the hot to the cold sides of the radiator. This is on a fully warmed up engine. It's an even larger drop on a cold engine when the thermostat is closed.
The ATF is run through the cold side of the radiator. Now if the engine is running at 200F and the coolant loses 100F going through the radiator the ATF cooler is surrounded by 100F water, not 200F water. That's the part that most people seem to have a hard time with. The radiator is NOT at engine temperature.
Always and never are pretty strong words. There is a possibility that there is some condition that I didn't test that does something weird. I did test in ambients from -40F to +115F, and at no time was it even close. The ATF was ALWAYS warmer than the coolant in the cold side of the radiator.
__________________
Mark
Tags
2004 , 350 , 5r110 , change , e350 , engagment , f350 , fluid , ford , harsh , replacing , reverse , shuder , torqshift , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
