Now not just the 7.3 Gods, I need the DIESEL GODS TOO STEP IN!!
Well I was talking with Derek from Outlaw Diesels and since having my issue with me thinking I had water in my tank. Well I took the fuel bowl off, cleaned it, started purging the line into a gallon jug to see if any crap came out and nothing but I did notice that the diesel was a orange yellow. He thinks I caught the Diesel Virus!
Bacteria in diesel - ¡Cure Diesel Contamination, kill bacteria, fungus and yeasts in diesel
Whats your thoughts? I filled up another gallon jug of fresh diesel and its a green as show in the picture. I mixed it with gas and water to see if it would change color and it didnt. The only thing I can think of is that the tank that i bought used had been sitting for 3 years that something was growing.
I think I'd hit it with a good biocide before I let all that fuel go to waste. Diesel Kleen doesn't have enough in it to use it for anything other than prevention. You need to dose it with the real stuff.
Biocide Racor Fuel Distillate Additive
Looks like orange juice to me, and it will probably run in your pickup about as well as orange juice would.
I don't know how many gallons of that you have, but it'll take a lot of biocide and filtering to have any chance of making that stuff fuel again. With a little bit of fuel and water left in the tank, it was a haven for diesel digesting bacteria, and would thoroughly inoculate whatever fuel you put in on top of it.
Yep, your truck has the diesel version of the clap.
I primed the tank till I drained every last bit out and it was dry. I filled a half tank of fresh diesel and nothing, still doing it.
I had it rescanned with a snap on scanner and these are the codes i got.
p472 exhaust pressure sensor low
p198 engine oil temp sensor high
p1690 waste gate solenoid control circuit
p381 glow plug indicator
p1140 water in fuel condition
Their only fix was to go to a specialty shop that continuously flushes a stronger biocide agent through the entire fuel system for many passes and then refills the tank with fresh diesel using a double dose of biocide additive.
For motorhomes with this problem it usually takes a few days/miles for enough new bacteria to grow to clog up their new fuel filters so it sounds like you might have other issues as well. Did you start off with a new fuel filter?
Well we hooked it up to a real ford scanner and its showing the number 8 is not firing. Did a buzz test and they all buzz fine did the contribution test and it came back not working. So shes clogged. My buddy that scanned works on these on the side, he said drain a gallon of oil, fill a gallon of Diesel Kleen up and let it idle for an hour. Then change the oil, sometimes this will unclog it.
Doesn't sound like a good idea to me, and it won't cure your problem if dirty fuel caused it.
