F3 questions
F3 questions
Just got a F3, 51 model has a 289 v8 in it with automatic transmison. All this was done before I got it. Couple of problems I thought somebody might be able to help with.
1st, It has a generator on it that has gone bad, what is the best soulution?
2cd, Has a sort of home made flat bed made out what appears to be diamond plating painted black and looks terriable. I can't find any beds around here to fix it so was thinking of cutting down the frame to make F1 bed fit it.
also, thought I would see what suggestions anyone had on having the motor gone through and leaving it in it. I know thats a bunch of info but any thought would help. I am knew to this. Just a note, I plan on having it restored. The truck is in really good shape, no rust holes or dents, or missing stuff on exterior. Just want some direction.
Welcome! Soon enough a few of the folks will come in and answer your questions. to answer your first question, I would say if it's a 289, it's already likely 12 volt converted. I would think a standard alternator would work. Unless the PO left it 6 volt, and hoped the points n the 289 dizzy would be ok. One other thing I would look at is how the engine is mounted. Is it an aftermarket tubular crossmember with the engine mounts? If you wanted to put an original flathead back into the truck, there's a different mounting set-up used. After a few posts, you'll be able to post pics, (we all like pics), and use the search function. Settign up a gallery and such is a good start also. Again, welcome.
I was reading another post about 12 volt conversions. I wanted to know if there is a way to tell if my truck has been converted. Most everyone thinks with it being a 289 motor it is, but I just wondered why it even had a generator on it. Maybe this is why the POs are sometimes held with such high regard on the post....again any ideas will help, you guys seem to know your stuff.
I'll add my welcome. Glad to have you hanging around.
While you've not brought it up, I'd suggest that you do a forum search regarding the F-3 stock wheels. If your truck still has the original 17s it'll be something you will want to deal with. If you have 16s, though, you can thank the PO for being good to you. If you've got the stock 17s we can go over the alternatives with you.
If it sits that low there's a good chance you in fact have a safe F-3. It's pretty easy to see whether you're safe or not. If you have stock looking 8 lug rims with 17" tires they are probably the killer two piece design that everybody tries to get rid of. The only other safer 17" rim made back then was sourced on Chevys so it's possible, but unlikely, you'd have them. If you have 8 lug x 16s, or any 5 lug diameter, you're home free on this issue.
Generator first. Take that sucker off and throw it AWAY! There are a couple ways you can go, and it largely depends on your plans to do the best you can Vs your budget.
Like Havi I would have to assume the 12 volt conversion has been done. I had a 289 in my 55 and it was a dream. But the generator on it turned it into a nightmare.
If it were my truck (and your money - tee hee) I would definately change it out to an alternator. Many types are available - Ford, GM, aftermarket.
In that light I would go with a "one wire" style - it has an internal regulator. That will negate the need to buy a regulator and wire it in.
The GM alternators were one wire, and Tuff Stuff makes one wire alternators for Fords. Ford also made one wire alternators for it's later model vehicles.
Here is the link to Tuff Stuff if you want to shop:
Products :: Tuff Stuff Performance
One wire alternators are available just about anywhere - new and used, and there are a number of excellent forums here on record discribing the installation in depth. Here is the link to one of those forums:
https://www.ford-trucks.com/article/...ord_Truck.html
Even with the added expense, I'd definately go with a NEW one wire alternator. I have a Tuff Stuff alternator on my 390 and it's fantastic!
With regard to putting an F1 Bed on your F3 (F2/F3?) it can physically be done but it's gonna look REAL funny. The reason is, the F1 has a shorter wheel base than the F2 and F3. The box on the F1 is smaller and called a "Pick-up" box. The box on the F2+ is called an "Express Box" and is both wider and longer than a "Pick-up" box.
Since you have to center the box over the back wheels, the shorter F1 Box on the longer F2 frame is going to leave a gap between the box and the cab and then there's theproblem of getting running boards to hook up correctly between the front and back fenders.
F2+ boxes in good condition are very difficult to find, and as far as I know are not being reproduced. Maybe you could find one somewhere, or buy a donor truck with one on it inexpensively.
Here's a picture:
Bob Jones just published on this site, CAD drawings for a Stake bed for the F series trucks. Perhaps yo umight consider putting a flat/stake bed on the back.
Here is the link to Bobs drawings:
https://www.ford-trucks.com/forums/8...s-finally.html
Good luck!
Thanks Julie for the info. I don't know If I mentioned it but I would not put the f1 bed on the full length f3 frame. I was going to have the length took out of it infront of the rear axel and behind. At least that is the plan since the beds for f3s are nearly inpossible to find in good shape. Just for everyones info I got the truck for free, through and inheritance so I can spend a little extra on some of these ideas since I have no cost in it yet. Thanks so much again
Holy crap!
That's the BEST Express bed picture I've EVER seen!!!!
Got a bigger copy?
~Jason
Got a bigger copy?
~Jason
Hi and welcome!
Here's a picture:
Good luck!
Here's a picture:
Good luck!
Those ae in the back of the "1944-1952 Body Parts Catalogue" BTW.
on
I don't know If I mentioned it but I would not put the f1 bed on the full length f3 frame. I was going to have the length took out of it in front of the rear axle and behind. At least that is the plan since the beds for f3s are nearly inpossible to find in good shape. Just for everyone's info I got the truck for free, through an inheritance so I can spend a little extra on some of these ideas since I have no cost in it yet. Thanks so much again
Great north, that was very helpful to see. Thats exactly what I am wanting to do. Do I need to look into doing something like you did with the suspension and rearend? Just checking. Someone else has brought that up. I will try to get pics on here so you guys who have seen this stuff can tell me whats best. thanks
on
Would a choice in rear components need to be made before cutting the frame...I just thought that it might make a difference if you had different length springs...it may not, I don't know...Also, did you interior painting yourself? If you so, is that a base coat clear coat or some kind of single stage, that was just something I noticed in your gallery that made me think ahead a little.
