2wd leveling Kit - Installed - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 08-30-2011, 09:35 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Quote:
Originally Posted by StealthAssassin View Post
I'm not real crazy about grinding the knuckle.
I meant the I beam
The amount you have to take off is very little look at #3 on this thread: http://www.ford-trucks.com/forums/10...kit-is-on.html and you will see how very little and where Frank had to remove material. I bought the adjustable cams and didnt end up using them, the alignment shop had the non adjustable type and we just used them.
  #47
Old 08-30-2011, 09:54 PM
StealthAssassin StealthAssassin is offline
StealthAssassin is starting off with a positive reputation.
The front end shop had 1.5 adjustable, where did you buy yours? The knuckle was still slammed against the ibeam with a ton more to go... Strange that worked for you guys.
  #48
Old 08-31-2011, 09:48 AM
RedBoat's Avatar
Rather Be Floatin
Sorry I dont remember where I got the adjustable ones but the alignment shop just had the ones to do the job an I ended up giving them the adjustable ones since I had no use for them. Have you done any grinding on the I-beam and spindle?
  #49
Old 08-31-2011, 02:43 PM
tojoski's Avatar
tojoski tojoski is offline
tojoski has a great reputation on FTE.tojoski has a great reputation on FTE.tojoski has a great reputation on FTE.tojoski has a great reputation on FTE.
Could be attributed to the fact that yours is a 99.. do you happen to know is it is one that is considered an early 99?
I know there are subtle differences in those, not sure if the suspension is different or not.
  #50
Old 08-31-2011, 03:33 PM
gradyc's Avatar
gradyc gradyc is offline
wellhead
gradyc is starting off with a positive reputation.
I got my dual adjustable camber bushings at NAPA.
I'm Like you. I had to pull my steering knuckles out twice and do some grinding on them both times. First time the alignement shop couldn't get it in alignment even with dual camber bushings installed. second time around it aligned up great. I have the aluminum spacers.
  #51
Old 08-31-2011, 04:32 PM
Yes, early 99
  #52
Old 08-31-2011, 07:46 PM
This leveling kit just really does not level or even the space from tire to fender either... Front compared to the rear.
I just wish more could be done with the twin I beam 2wd
Susp.
Center i beam Drop brackets seems would be the best answer if they would work.
Are you guys springs sitting straight up or angled out?
  #53
Old 08-31-2011, 10:52 PM
tojoski's Avatar
I just realized that this was my old thread.. look at the pics on the 1st page and you'll see that my springs were initially unlevel as well. Modifying the spacer helped.
  #54
Old 09-03-2011, 05:04 PM
Angry
Ok, this kit will not work on my early 99. I adjusted a 2 1/2" camber bushing all the way down and my wheel still needs to come back in atleast 1"+!
this kit will not work without 2" drop brackets which nobody makes...
Maybe because they won't fit and still get it bolted down?...
The I beam or spindle must be different on the early 99 vs. Late 99.5 and up.
If anyone knows if they are different, but compatible, please let me know.
As far as grinding, I maybe had to grind about a 1/8" and the 2 1/2" bushing still did not bottom out.
Wow! I'm not so happy and I really want this to work!
  #55
Old 09-05-2011, 02:40 PM
  #56
Old 09-05-2011, 02:46 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
The aluminum leveling kit that many of us have used worked just fine on my e99. The rotors and bearings may be different on the early birds, but I dont think they changed the I beams any.
Mine is a 4/98 truck, so Its def an early bird.
  #57
Old 09-05-2011, 02:47 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Starting to think, its way to much of a headache, for not much conclusion. Think the $800 4in or 6in lift, that has everything..drop brackets, radius arms, springs, would be a much better route.
  #58
Old 09-05-2011, 02:55 PM
Mine was made in 98 also. The I beam or spindle must have changed at some point.
4" sounds like the route I will take, I guess...
The wheel is still riding on the outside of the tire with this much camber adjustment, which is max and well over 2wd specs
  #59
Old 09-05-2011, 02:59 PM
I will take a long distance pic to show the wheel camber and you tell me how to make this work and I will eat my words.
Maybe the angle shows up more on these 34's on 20's
  #60
Old 09-05-2011, 03:00 PM
I know there are more different specs on the 05/07 like wheelbase width
4x4 Conversion using RSK and Dana 60 Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 44 01-13-2012 07:34 PM
Possible Crewcab F250 2WD for sale Roller150 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-04-2011 08:13 AM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 01:02 PM
progress update on the bed make over. 65fordguy 1961 - 1966 F-100 & Larger F-Series Trucks 10 11-12-2009 01:26 AM
My 2009 F-150 Platinum morgan867 2009 - 2014 F150 56 01-01-2009 03:59 PM
Tags
2000, 2wd, billet, bolt, dually, exstenders, f150, f250, f350, ford, installation, kit, kits, leveling, spacer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
