2wd leveling Kit - Installed - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-15-2009, 08:35 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
That's where I got the $10 price from, Jim. For the length of these bolts, they won't fit even at an angle in the smaller $4.50 boxes, and the next size jumps to about $10 really quick.
  #32
Old 04-16-2009, 06:29 AM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Ok I was just throwing it out there.
  #33
Old 04-16-2009, 09:58 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Eegads! I didn't realize those bolts were that freaking long.
Stewart
  #34
Old 05-02-2011, 06:37 AM
arusty1's Avatar
arusty1 arusty1 is offline
arusty1 is starting off with a positive reputation.
Old thread, I know, but this is the info I came up with on this topic;
I installed 2" aluminum spacers only to to find out that it can't be aligned without grinding the upper part ot the spindle,
and..
if that's done it still puts the upper ball-joint to the outside of it's range of motion.
Not to mention that the loss of castor is unrecoverable.
The correct way would be to use 2" drop brackets which nobody seems to make.
'03 250 2wd sc/sb
Any help would be appriciated.
...Rusty
  #35
Old 08-30-2011, 01:39 PM
StealthAssassin StealthAssassin is offline
StealthAssassin is starting off with a positive reputation.
The leveling kit for the 2wd does not work...
  #36
Old 08-30-2011, 01:41 PM
Ditto about the drop brackets! Wth does daystar sell this kit when it does not include drop brackets???
  #37
Old 08-30-2011, 03:09 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Quote:
I hate to disagree but the leveling kits do work, Many of us here (myself, grady, Frank, Joe) have them installed and aligned without any problems. On some trucks the spindle does have to have a little material ground off. If you feel "lucky" try the install without removing any material, the downside if you do have alignment issues you need to remove the spindle and do a little grinding. I had to remove about 1/16" inch off of mine (really quick job with a grinder).
Rusty, if your alignment guy cant get it aligned find another front end guy because it can be done.
Check out this thread:
http://www.ford-trucks.com/forums/10...kit-is-on.html
  #38
Old 08-30-2011, 03:36 PM
Stewart_H's Avatar
What do you mean it doesn't work? Are you saying it doesn't lift the front-end at all, or are you saying the truck isn't perfectly level after installation?
If you're saying it isn't perfectly level, then yea, you're right. There is still a slight front-to-back rake. But I like that.
Stewart
  #39
Old 08-30-2011, 03:42 PM
Stewart_H's Avatar
Quote:
Originally Posted by RedBoat View Post
I hate to disagree but the leveling kits do work, Many of us here (myself, grady, Frank, Joe, Stewart)
http://www.ford-trucks.com/forums/92...ml#post8492932
Added a little to your quote.
Stewart
  #40
Old 08-30-2011, 05:49 PM
RedBoat's Avatar
Rather Be Floatin
Sorry I missed ya Bro!
I probably missed quite a few others: Parts Guy Ed, Big Joe, JoRge, Chris..........
  #41
Old 08-30-2011, 06:44 PM
gtnwood's Avatar
gtnwood gtnwood is offline
gtnwood is starting off with a positive reputation.
I have the aluminum kit installed as well, no grinding required but did need to get a cam kit since the alignment was out of tolerance adjustability but it rides smooth as a you know what now and looks better to. Franko helped me immensely during my install cuz it was about to be yanked off till gettin with him.
  #42
Old 08-30-2011, 07:26 PM
Ok, how did you get the camber adjustment right? The steering knuckle hits/bottoms out the I beam before the wheel even gets plum by eye...
  #43
Old 08-30-2011, 07:28 PM
tojoski's Avatar
tojoski tojoski is offline
tojoski has a great reputation on FTE.tojoski has a great reputation on FTE.tojoski has a great reputation on FTE.tojoski has a great reputation on FTE.
Mine installed without any grinding, although it was pretty close..I had to get the adjustable cams to get it to align,
I'm still running the older hard plastic type, one of these days I'm gonna switch them out for the Aluminum ones.
  #44
I'm not real crazy about grinding the knuckle.
  #45
Old 08-30-2011, 07:43 PM
I meant the I beam
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 09:46 AM
4x4 Conversion using RSK and Dana 60 Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 44 01-13-2012 06:34 PM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 12:02 PM
Some pictures of the Body Work Red Ford Truck Ontario Chapter 27 07-26-2009 08:12 AM
Dual exhaust pics Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-12-2009 08:50 AM
Tags
2000, 2wd, billet, bolt, dually, exstenders, f150, f250, f350, ford, installation, kit, kits, leveling, spacer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
