Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-13-2009, 12:27 PM
equium equium is offline
equium is starting off with a positive reputation.
'99 E150-runs poor after battery disconnected
I had to remove my battery to get to my Blower motor resistor. The battery was removed for about an hour or so. After re-installing the battery, my check engine light went OFF (yes, off) and ran a little rough. It seemed to clear after a trip to the movies.
My wife just called and complained it's running rough and the check engine light is back on.
any ideas?
thanks
__________________
99 XLT Clubwagon E150
5.4 Triton
11 passenger
91 F250 XLT Lariat (4X2)
7.3L IDI
  #2 (permalink)
Old 04-14-2009, 01:06 AM
Club Wagon Club Wagon is offline
Club Wagon is starting off with a positive reputation.
I've heard OBDII can loose some of it's adaptive memory when battery is disconnected & older vehicles that have strayed from the straight & narrow may run poorly until the computer relearns the aging values. It can revert to programed values. This can take several start/stop, hot/cold, cycles. It can also happen when new components are installed, the computer needs to go thru a few cycles to learn the new values. Can make you pull hair out when the new gizmo doesn't immediately solve the problem. Give it an hour or several start/stop cycles. If CEL persists scan the fault code.
  #3 (permalink)
Old 04-14-2009, 09:44 AM
Quote:
Good Call Club Wagon. By the end of the day, my wife reported that the van was behaving well; but the Check Engine light did come back on. Now I just have to get the code read 'cause I need a smog check.
__________________
5.4 Triton
11 passenger
7.3L IDI
  #4 (permalink)
Old 06-21-2009, 06:04 PM
Update: The check engine light was due to a disconnected PCV valve. I replaced it and the Check engine light went off and I passed smog with no problems.
Now here's the kicker: My van has been running like crap ever since the Smog check! Could they have done something? I replaced the fuel filter thinking it may be plugged but that did not help. Air cleaner is fine. I have less power than before the smog check. pulls hills like I'm towing something heavy. I don't hear a miss. Any suggestions?
thanks
__________________
5.4 Triton
11 passenger
7.3L IDI
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
