Wiper question
Received 4,132 Likes
on
Wiper question
I have a question regarding electric wiper motors. I was planing to use the wiper motor from a chevy pickup that I have as a donor. When it was still hooked up the wipers would park in the down position. Now that I have the linkage disconnected the motor continues to rotate with the wiper switch turned off and will only stop when you turn off the ignition key. I was hoping that the motor would self park so I could use it in my 56. Are all motors not treated equal?
John
John
John
John
try a seperate/adding a ground to the motor casing.
the park curcuit is likely missing it and just bypass's the signal and goes into another sweep.
on
John
i might be newb but hey.
even in 74 the park curcuit was in the motor. try grounding the case.
http://www.rowand.net/Shop/Tech/imag...erDiagram1.jpg
on
Delay Wipers
no problem.
sorry if i came across rude.
just some guys don't give newb's the benefit of the doubt.
no problem.
I knew I could count on you Julies to respond. I had it plugged back in the truck I took it out of but not hooked up to the wiper linkage. A friend of mine said that it probably needs to find a place to park and not being hooked up can't get that signal, does that make sense?
John
John
Yep makes perfect sense. Wiper parking is as much a function of Voodoo as science. There is a relationship between the motor and switch that causes the wipers to park. I can conceptualize it in my mind but it wouldbe more confusing to try to write it down. Basically, it has to do with the position of the switch that causes (or tolerates) either mechanical or electronic cut outs that elliminate power or ground to the motor to stop the wipers in a certain place.
So the consistency in type between the motor and switch is important.
If you hook up the switch for the wiper motor you have, it will park the wipers. But that position is a function of the angle it was designed to stop at the motor to put it's stock chevy wipers down with the chevy linkages. It will stop at that angle at the motor now as well, but whether or not your wiper linkage is in the correct position to park the wipers down where they are supposed to be remains to be seen.
Did that make any sense?
on
Delay Wipers
no problem.
no problem.
Now to what I did this morning. I plugged the motor back into the pickup, grounded the main frame of the motor,both to the body of the truck and directly to the battery terminal, with the switch in the off position, it still continues to rotate. I don't know if when I tried to start the motor on my bench if I could have shorted something out. I may have to see if I can get another motor to see if that is my problem.
What I'm trying to do in imitate what New Port Wipers did without the expence of purchasing thier wiper motor, every time I purchase something it ends up costing me twice as much as what they're asking, cross border shopping is expensive. I'll post some pictures of what I've done so far.
on
Hi
John
on
HI again.
Also, if you can get a wiring diagram from the chevy to make sure you have all the wires hooked up correctly, that might help.
I migth also be tempted not to add any grounds outside of that is on the switch and motor originally, some of these motors park by ellimination of the ground created by an eccentric cam and set of points. If it has a constant ground, the points may be bypassed.
on
HI again.
Hi
motor needs power & ground to run.. when the switch is ON, its pretty easy.. but.. ad the thought that you want the motor to STOP in a specific spot ALL the time.. hmm...
the trick.. when the motor starts to turn, it moves a (spring loaded) tab that supplies power to the motor into connected state.. so you have TWO power feeds.. one from the switch, and one internal..
the ring that pushed the connector up has a gap in it.. and so, when the armature gets around to that point, the connector disconnects, and if the primary feed wire is off, then the motor stops.. this is the end of the cycle.
intermittent starts it back up again by pulsing the primary feed, which starts the motor, pushes the connector back up, drops the primary lead, and one cycle the connector drops and poof, off again..
the intermittent logic can have a variable delay time.. or positional fixed delay times..
so, intermittent is really just repeating parking!!..
the 'park' position is a factor of the motor rotation, the motor arm length, etc,etc... the motor doesn't know anything about the wipers themselves.. it just goes around til it runs out of power..
Sam
