I get a noise for the engine compartment when the truck is off. It sounds like a inexpensive air compressor. Also I get the same noise when I start the engine sometimes. It is a 98 expediton with a 5.4. Truck seems to run fine otherwise.
Does it make the noise no matter if the AC was run or not? Note AC may run in any position except Off, Panel, or Floor. A fully pressurized AC system & hot engine can turn the compressor over for a little while "when truck is off".
