NP435 Help with shifter removal - Ford Truck Enthusiasts Forums
Old 04-12-2009, 03:22 PM
Wyatt66f100's Avatar
Wyatt66f100 Wyatt66f100 is offline
Wyatt66f100 has a good reputation on FTE.Wyatt66f100 has a good reputation on FTE.
how do i get the shifter off without tearing apart the tranny? its in the way of me taking the cab off.
Old 04-12-2009, 03:30 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
pm me your number...will call and tell ya...
check email
- cs65
Old 04-12-2009, 05:33 PM
bigblockford_390 bigblockford_390 is offline
bigblockford_390 is gaining momentum as a positive member of FTE.bigblockford_390 is gaining momentum as a positive member of FTE.
If you did not get a hold of CS65 yet, once you remove the rubber shift boot down on the floor you will see a tower coming out of the transmission where your shift lever is. There is a cap that you must push down ( there is a fair amount of spring pressure under the cap) then twist the cap about a 1/4 turn. If my memory is correct you will turn the cap counter clock wise and then it will pop up. Then the shift lever will lift right out.
Make sure the transmission is in neutral before you pull the lever out.
Installation is just the oppisite and really can almost be a two man job. One to push down on the cap and the other to twist it.
That is one of the reasons why I perfer the T-18 transmission as the cap just twist on with threads as opposed to a 1/4 twist setup.
Jeff
Old 04-14-2009, 10:32 PM
cool got it first try. used the smallest pry bar i have and the biggest flat head screw driver. pushed down and turned and bang. it was out. thanks for the help.
Old 04-15-2009, 02:34 AM
NP...told ya that spring was a tough pup...check the parts close for cracks or whatnot...easy to replace them now if needed...
- cs65
Old 04-15-2009, 05:40 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
New Process 435 Shift Lever Retainer Cap
B8T7220D .. New Process 435 Shift Lever Retaining Cap
Most ppl are unaware that you have to press down on this cap, and hold it down while turning it.
If you do not press down, the notches tear out of the cap.
Ford just obsoleted this cap, but there are 100's still around at dealers and obsolete parts vendors.
Here's some examples:
BILL PIERRE FORD in Seattle WA has TEN.
WOODY BILTON FORD in Moncks Corner SC has SEVEN.
JOE MACHENS FORD in Columbia MO has FOUR.
KENNITH WESSNER FORD in Winchester TN has FOUR.
PARTS INTERNATIONAL in Farmers Branch TX has 21 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 31 = 800-543-4959.
Old 04-18-2009, 10:52 PM
I'm Rebuilding the tranny myself at work one of these days. except our parts guy is a little bit of a dumb a%^. lol good thing we got number dummy. hey don did you ever get over to tonys for that firewall pad?
Old 04-19-2009, 02:10 AM
no I didnt...no trip to Pdx this wkend...maybe next wkend though...
- cs65
Old 04-20-2009, 07:44 PM
doc66 doc66 is offline
doc66 is starting off with a positive reputation.
On the topic of shifters, where can I get a new shift lever for my 66 4 on the floor? The PO, for some reason, had one that was sawed in half and appears to have extended it with a piece of pipe. I'd like to get one that's chrome. Any leads would be appreciated.
Old 04-20-2009, 09:05 PM
Hurst makes a eye candy one. i just cant find it at the moment. they have a 3 speed **** and a four speed ****. but i know they make the full shaft as well.
manual 4wd shifter pass1over 6.0L Power Stroke Diesel 8 05-07-2016 05:52 PM
2003 Escape Shifter Cable Adjuster Expedang Escape & Escape Hybrid 1 11-10-2014 09:46 AM
Manual 2001 ford ranger shifter knob Honda Monster 222 Ranger & B-Series 5 06-28-2013 03:54 PM
Overdrive light on shifter is flashing Cesposi1 1999 to 2016 Super Duty 25 10-16-2010 06:54 AM
broken shifter linkage on automatic tranny Stroker Ace 1994.5 - 1997 7.3L Power Stroke Diesel 4 01-17-2009 07:50 AM
Tags
435, ford, lever, np, np435, parts, process, removal, remove, retainer, shift, shifter, shiftlevers, tower, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
