99psd wont start, battery issue?
I have a 99 7.3 with 255K on the clock. I have owned it for 3 years and it has been very reliable. I can't recall ever being stranded and I don't think i have had to jump it once in 3 years.
Today I was trouble shooting an 93 f250 with the diesel motor that has been a hard stater all winter. I swapped the batteries from the 99 to the 93 to eliminate the battery question on the 93. Swapping batteries did not help so I put the batteries back in the 99 and of course, it would not start.
When I turn the key on the dash lights do a dance and surge and dim and then when I crank the starter it just clicks, like a dead battery. Put battery charger on and charged for about an hour on the 40 amp setting. Still no start, it turned over a little. Put the charger on 200amp boost, a little more crank but no start. Still getting a weird light show on the dash waiting for the glow plugs to heat.
I think it sounds like a bad ground, but not sure why it would act up after just removing batteries for about an hour. I currently have the charger on trickle and will try again before I hit the sack. Not my Daily Driver anymore, I bought an 02 two weeks ago, but before that 25,000 a year with not one starting problem. Did I mention I have 255,000 miles on this truck? Batteries are 800 plus CCA but I have not replaced them since I bought the truck so I do not know how old they are.
Any thoughts or suggestions?
This is a great site and the diesel section has some of the most intelligent discussion on the fte boards. Thanks for all the ideas over the last three years and for any help on this particular problem.
Thanks megawatt, but what happened to burn those batteries or is it just coincidence? Like I said that 99 has started like a champ for three years every day. We ran it just two days ago and no problems. And today was in the 50's so not really that cold out?
I detest buying parts trying to solve a problem, if it is the batts, something in the 93 drained them, they were in the 93 for about an hour.
The batteries could have been on the weak side. By putting them in the 93 and trying to start it, it could have just drained the remaining life out of them. You can always charge them and then load test them to see. Where you don't know how old they are I would consider changing them out anyway. You never know when they are going to let you down.
There's a chance the batteries were weak, especially since it's not your daily driver anymore, and the excessive cranking with the 93 pushed them over the edge. You might try taking the connections off, cleaning them, and sticking them back on, but I'd suggest taking them to an auto parts store and let them load test the batteries for you. Most stores will do this for free. That way you'll know before you dump money on new batteries.
Edit: Too slow again.
Ok thanks for the suggestions. I can get them tested on monday no problem. I hope that is all it is. I want to sell the 93 if I can get the no start fixed. New batteries are not out of the question as I don't know how old they are, but I do know they have been reliable. Would low voltage cause the wierd dash lights issue?
Just a quick update, I trickle charged for about 6 hours last night and this am, Still no start and I don't think I am gaining on the crank time, just barely turned over once this am and then Click... It looks like a new set of batteries are in order. Below freezing this morning so that probably contributed to the hard crank.
Here are a couple of thread that you may find intresting to read on the GP system and battery system in our trucks.
https://www.ford-trucks.com/forums/7...y-q-and-a.html
https://www.ford-trucks.com/forums/7...pr-system.html
A fresh set of batteries will take care of your problem. Make sure that your connections are clean and tight and I reccomend using Noalox on the terminals to prevent corrosion.
Keep us posted. Maybe the Easter Bunny should have brought you a set of batteries!!
I wish I had confidence in the cable repair ends you can buy. The ones I have used are usually the first thing to fail, I think the best ends need to be crimped on. I am going to have to break down and fix the ends on the 93 I think, if I figure out a good repair, I will probably fix the 99 as they are starting to show some wear.
Glad this is not my daily driver or I would be working on this today instead of easter day family plans.
The bunny left me jelly beans.
Gonna take a few days as I am starting a block job in another town early tomorrow and plan on working big days to knock it out this week. I will probably get batteries tomorrow and hope that gets the 99 going.
Had the trickle charger on all day today and no start just click. Even on 200 amp boost I couldn't get the truck to turn over, I hope I don't have something else going on. Well one step at a time.
Well I have a crimper, but for smaller wire, nothing that big, but the local napa (20 miles away) can put ends on for me so I will probably go that route when I get that far.
Thanks for the welder cable idea, I might just try that.
Don't need luck on the block job, just a little time. 18 walls 11 block long 8 courses high, spend more time building leads than laying the fillers. Just me and a tender so should be able to get r done without too much trouble.
