Alternator/Power Steering bracket - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-11-2009, 08:17 PM
Fr. Frank Fr. Frank is offline
Fr. Frank is starting off with a positive reputation.
I have, for the 3rd time, had the cast aluminum bracket break to which my power steering pump and alternator mount on my '02 F250 7.3L. Last time the bracket alone cost me $221 as a carry-out item. (First two times were under original warranty)
What sources are there besides paying the dealer $221?
I asked LKQ and was told they don't separate the bracket from the motor, and I'm not going to pay $3800 for a used motor just to get the bracket.
Ideas, suggestions?
Old 04-11-2009, 08:25 PM
rebelchevy02's Avatar
rebelchevy02 rebelchevy02 is offline
rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.
Do you know what is causing the break to happen?
Old 04-11-2009, 08:33 PM
No, I don't know what is causing it. First break came at about 73K miles, second bracket break came at 81K, and this one came at 164K. They have all broken in the same place, too. They break across the opening in the bracket through which the pulley shaft from the PS pump protrudes.
And, yes, I have changed the PS pump, at 81Kmiles ('cuz that's what the Ford dealer said was causing the aluminum to fatigue and crack), and again at 145K miles, when the pump began leaking past the seals.
Old 04-11-2009, 08:34 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
Were is it breaking? That bracket is pretty beefy. Can you take a picture of the break?
Is there somthing between the bracket and block causing it to not sit flat and when you tighten the bolts it puts it under stress?
Old 04-11-2009, 08:36 PM
I'll get a picture of the break tomorrow, after church is over.
Old 04-11-2009, 08:48 PM
swaybar swaybar is offline
swaybar is gaining momentum as a positive member of FTE.
once, MAYBE, but to break three times there's got to be a reason causing this and i'd search for the cause.
i have no ideas but i have had that bracket off of mine and i know its solid.
Old 04-11-2009, 09:01 PM
danskool's Avatar
Go Bills !
Fuel rail Plug causing it not to sit flat? Does the bracket have a big enough recess on the underside to clear this plug? There is also a 4th mount hole. Just below the picture shows.
Old 04-13-2009, 07:51 AM
I pulled the broken bracket off, and found the stub of a broken bolt or stud behind the bracket, protruding about 1/8" to 3/16" from the head. It appears to partially line up with a recess in the back of the bracket. The local LKQ auto parts guy says my truck probably was OE with the dual alternator setup, which uses a different bracket. Unfortunately, he didn't have a replacement in stock, nor one in Florida. So now I go cry to the dealer who replaced the bracket last time, and demand to know why their tech didn't remove the broken stud or bolt the last time they replaced this bracket, 2 1/2 years ago. Wish me luck.
Old 04-13-2009, 09:31 AM
Actually as far as I know, the bracket on the drivers side, which includes the powersteering pump, and alternator, is the same, whether or not it has dual alts or not. The optional bracket is on the passenger side. I have been askeed before at the ford garage which side the alternator was on, so they can put a secondary alternator on the drivers side somewere, but I think standard dual alts, is drivers side, ontop, and passenger side, on the bottom.
Will v8 power steering brackets work on the 6cylinder engine? four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-06-2016 08:29 AM
460 conversion ?s nichc 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-15-2014 12:54 PM
302-351 accessory brackets interchangable? nickmobile67 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 08-02-2011 03:10 PM
Altenator Belt issues with 1990 7.3l diesel JoeFordUser Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-09-2011 09:46 PM
Alternator mounting woes, 1985 460 Handegard Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 03-24-2009 12:57 AM
Tags
1999, 73, 99, altinator, bracket, brackets, broke, diesel, f250, ford, power, powers, powerstroke, ps, pulley, pump, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
