Too much smog crap
Welcome to FTE. What you're attempting is what ends up causing all sorts of problems. Why do you want to remove it anyway? I'll save you all the details, but everything is set up to work together, and removing one component without compensating with the engine's timing curve and fuel mixture becomes a painful trial-and-error process that, at best, gets you to where you were in the first place.
Generally, those that remove all the emissions equipment and can successfully tune it back correctly (which is difficult since the carb is designed to run with it), gain only a couple horsepower, if any, and no real change in fuel economy.
As complex as the smog system looks, it really doesn't take a lot away from your engine. The easiest way to get your engine running at its best is to be sure all of that equipment is operating correctly.
That being said, I passed emissions with the sniffer test with a brand new cat but without a smug pump or an EGR valve. I had a really hard time getting the engine to run right though. It always bogged at idle, ran too rich at idle, too lean when driving, etc.
If you're looking to fully modify your engine, replacing the intake and exhaust manifolds and putting on a new carb like a 2bbl or 4bbl will bypass all of the emissions equipment. There's plenty of writeups on here in that regard. Just be sure you don't have emissions (and please still put a cat in your exhaust. )
To remove stuff just to remove it rather than repair and maintain as needed is junk auto science. If all the stuff is removed than all the systems have to be re-engineered to non-emissions operation. Do your trouble shooting and repair/maintain as necessary starting with checking for vacuum leaks. The EGR is probably shot/burned out and the Cat is probably plugged or blown out.
There's no re-curving an '86 TFI distributer. He will need to replace it with a DuraSpark II distributer and also add the DuraSpark II module. My '85 has all the smog crap on it and it runs fine. IMHO there is nothing to be gained unless you do everything (4V, cam, compression etc) and then it's up to you to tune it.
Just do the Dirt Cheap Ignition set up. It cost me less than $100 to the swap on my 84. I was able to junk the TFI distributer and keep the E Core coil. I am running a 75 model duraspark distributer, and a 78 Z28 HEI module. All of the smog system is removed from mine including cats, and it runs great while averaging 20 mpg.
