Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 05-06-2009, 04:03 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
thanks for the info. I wonder where I could find out what they did to these old tanks - and possibly the Bronco II tanks as well.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #47 (permalink)
Old 05-06-2009, 04:36 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
1964/72 Ford Truck Parts Catalog / Text / Section 90 / Page 1 / Fuel Tanks
DOTZ9002A .. 19.5 Gallon Fuel Tank (DOTZ-9002-A replaced C1TZ-9002-F & -H)
Fits: 1961/72 F100/850 (GAS)
Fits: 1964 N600/700 (DIESEL)
Fits: 1967/72 F600/700 (DIESEL)
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #48 (permalink)
Old 05-06-2009, 05:09 PM
1974 Ford F-250
Thanks number. Is there a picture of the tank? Is it an in cab type tank with a shape like the one in my 74 crew so as to possibly "bolt" into my truck? I think it is based on the part numbers, etc. in your earlier post.
You also said in that earlier post that these tanks (NON-evaporative version) are reproduced by Blue Oval Parts. Maybe I could use one with vented fuel cap. I would still be concerned about what the tanks are coated with and would look into that if I get one.
You show that the same tanks were used with gas and diesel, but I wonder if they knew back then that the diesel reacted with the certain coatings?
__________________
1970 Ford F250
  #49 (permalink)
Old 05-06-2009, 05:19 PM
Ford Parts Guru
You show that the same tanks were used with gas and diesel...
...but I wonder if they knew back then that the diesel reacted with the certain coatings?
That's a good point...this parts catalog was last printed in 1975, so...
The in-cab tank will fit thru 1977, but you'll have to change one fitting and the filler hose.
DOTZ9002A = This is the SAME tank BLUE OVAL has reproduced.
Since this is a NON vented tank (as original)..you'll have to use a vented fuel cap, otherwise...
__________________
  #50 (permalink)
Old 05-06-2009, 05:29 PM
1974 Ford F-250
Cool deal - looks like I might have to call Blue Oval and see if the tanks are diesel safe. Who wants to bet they don't know what the coatings they use for these things are....
As for changing the one fitting and the filler hose - do you know what the exact differences are? I would assume the filler location was a bit higher or lower on the ealier trucks and hopefully the actual hose connecting that to the tank could be changed. Is that correct - or close?
What about the fitting? I would think since I will be running new fuel lines this shouldn't be an issue.
Thanks.
__________________
1970 Ford F250
  #51 (permalink)
Old 05-06-2009, 05:56 PM
Ford Parts Guru
The filler neck is different as is the hose, because the body style changed in 1973.
There's only a few inches of space between the neck and the tank.
If you use a flexible filler hose, or one with a slight bend, there shouldn't be an issue.
__________________
  #52 (permalink)
Old 05-06-2009, 05:58 PM
1974 Ford F-250
thought so - thanks
__________________
1970 Ford F250
  #53 (permalink)
Old 06-09-2009, 03:23 AM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
Poly Tank
I picked up a poly tank from a 97 F-450 Superduty Diesel....It will fit between the frame rails on a Highboy....Not sure of the capacity...but looks to be pretty good sized....I haven't put it up in the frame to see how it sits..but by the measurements it should work quite well....I may have to drain it out and crawl under "Old Yeller" just to see for fun...LOL
__________________
1979 F-350 4x4 Dana 60's Front And Rear
1978 F-250 Supercab 4x4 w/Dana 60's front and rear
1978 F-250 4x4 Crew Cab Waiting For A Cummins
1976 F-250 Highboy Tow Truck
1979 F-150 4x4 Shorty
Way Too Many Trucks to list 29 Total So Far!!
  #54 (permalink)
Old 06-09-2009, 03:25 AM
galvanized tank
Are you sure the 74 tank is galvanized??? I don't recall my 74 being galvanized....That is weird seeing your in cab tank chasetruck...first time I've ever seen the highboy tank with the extra evap line on it!!!
__________________
  #55 (permalink)
Old 06-09-2009, 01:54 PM
1974 Ford F-250
Quote:
Hmmm - what are the overall dims on that tank? I am still trying to figure this one out, but I will most likely build a custom, aluminum tank for it. My problem is trying to fit my winch back there along with the tank. I have looked at the Bronco II tanks and it seems just barely too big with the winch there. I am in the middle of figuring out just how far back I can get that winch to mount, so I can see how much room I have left between the winch and axle.
That's good old california smog crap for ya! And yeah - I'm prety sure it's galvy under the paint. The one Ed has lying around was cleaned up and it is for sure galvy...
__________________
1970 Ford F250
  #56 (permalink)
Old 06-09-2009, 09:07 PM
The Poly tank from the F-450....has a big top on it...Not sure if it has a fuel pump in it or not....But i'm sure it has a return line on it....I'll try and snap a couple pics of it so you can see what it looks like.
__________________
  #57 (permalink)
Old 06-09-2009, 09:08 PM
1974 Ford F-250
Thanks. I had looked at a rear tank from a 2004 F-450 a guy was parting out, but it looked way to big to fit between the frame rails on the highboys. Maybe this one being from an older body style will work...
__________________
1970 Ford F250
  #58 (permalink)
Old 06-09-2009, 10:05 PM
My old boss was storing the truck at my yard when I had my shop...He just let me have it....I was all over it cuz of the dimensions and poly
__________________
  #59 (permalink)
Old 06-25-2009, 07:34 PM
samthelion's Avatar
samthelion samthelion is offline
samthelion is starting off with a positive reputation.
In cab tank
I'm with Festus Hagen: I'm too chicken. I would go with the '87-'97 behind the axle 17 gal. or aftermarket, 36 gal. tank with the in tank fuel pump,and get that tank out of the cab. Any good boneyard can help you with the plumbing (hoses, valves, connectors, wiring) even an in-tank low pressure fuel pump. Gastanks-r-us got the stuff.
Good luck, my friend, be safe.
  #60 (permalink)
Old 06-25-2009, 08:07 PM
1974 Ford F-250
I decided on not using the stock (or replacement) in cab tank a while ago. I'm not too concerned with it being in the cab as it is diesel and not quite as flammable as gas, but still - the capacity isn't there.
I will most likely build a custom aluminum tank for the rear. For what people want for aftermarket stock tanks I can make my own to the shape and capacity I desire for less...
__________________
1970 Ford F250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
