Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 04-28-2009, 12:55 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
good to know - thanks Brady.
I don't have any others besides the one on the crew to compare to and it's been a while since I had the other trucks so can't remember if that thing was normal or not.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #32 (permalink)
Old 04-28-2009, 12:59 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
here is what mine looks like.
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #33 (permalink)
Old 04-28-2009, 10:07 PM
Beef Stew Beef Stew is offline
Beef Stew is starting off with a positive reputation.
I'm doing an EFI 5.0 swap into my '71 F-100. I used the original feed line as the return line and I added a sump to the bottom of my tank and plumbed in a new feed line.
IIRC diesel injection pumps do not like to pull fuel which you're making it do by using the stock fuel line. You're best bet is to pull the tank and add a sump like I did. I rinsed mine out like 5-6 times with just water and then added in a bunch of Palmolive for one last rinse. After the cleaning process the inside of the tank smelled more like soap than gas. I drilled a hole in the bottom of the tank and added in a 4" piece of scrap steel tubing that extends down past the cab. The end of the tube sump is capped and drilled and tapped for 1/2" NPT. I welded it all together without a problem. No explosions or fires.
Keep using your vent line for what it was meant for.
  #34 (permalink)
Old 04-28-2009, 11:00 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Beef Stew,
That is what lift pumps are for.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #35 (permalink)
Old 04-28-2009, 11:33 PM
bendog's Avatar
bendog bendog is offline
bendog is starting off with a positive reputation.
Quote:
Originally Posted by 71cc View Post
From what I have read diesel fuel will attack the galvanizing inside the tank.It makes it release from the metal and get into your fuel system.I would research some more.It would be nice to have some way to drain water off the tank as well.
X2 Not sure where I heard it, in fact when you first started this thread I typed up a reply to this effect, but deleted it when I couldn't remember where I had heard it.
__________________
1976 crew cab, 4x4, family tow monster. 97 Dodge Cummins engine doner.
  #36 (permalink)
Old 04-29-2009, 12:28 AM
Quote:
Originally Posted by Festus Hagen View Post
Beef Stew,
-Enjoy
fh : )_~
I didn't see any indication that the OP was going to use a lift pump.
  #37 (permalink)
Old 04-29-2009, 10:51 AM
71cc 71cc is offline
71cc is starting off with a positive reputation.
Quote:
Here is some backing..
Handle Fuel with Care
scroll down to "contamination"
Do not store diesel fuel in galvanized containers because the fuel may dissolve the zinc coating, which can then remain in solution until deposited in the pump or injectors. Fuel additives often contain alcohol or another solvent that can dissolve plastic parts. Use additives with extreme caution—only after considering the engine manufacturer’s recommendations.
Here is some more from "official" sources. LOL
Section
\5\ Gasoline fuel tanks constructed of iron or steel, which are less than 5 millimeter (0.1875 inch) thick,
shall be galvanized inside and outside by the hot dip process. Tanks intended for use with diesel oil shall
not be internally galvanized.
There are plenty hits if you Google it. It is a concern.
  #38 (permalink)
Old 04-29-2009, 03:29 PM
1974 Ford F-250
Well crap. There goes that idea
Time to go back to the plan of just putting the dodge tank in my bed until I figure something else out.
Anybody here know if the Bronco II gas tanks are metal or poly/plastic?
__________________
1970 Ford F250
  #39 (permalink)
Old 04-29-2009, 03:48 PM
Two steps forward and three back, I know the feeling. the bright side is you know now, not later when you have Pump and injector problems.Look in my gallery, I mounted a factory aft axle tank for my conversion.The only trick is mounting a filler for it.I believe a van has a similar tank for narrow frames.It is only like 17 gallons
  #40 (permalink)
Old 04-29-2009, 04:43 PM
1974 Ford F-250
Yeah - it's better to know now rather than later so thanks.
I looked in your gallery but didn't see any pics showing the tank. Do you know what it came out of?
I'm going to be looking a bit closer at the new stupid-duties to see if they might have a tank I can adapt. If that doesn't work I can always make an aluminum one, or use the spare 36 gal. fuel cell I had for the ranger.
__________________
1970 Ford F250
  #41 (permalink)
Old 04-29-2009, 04:55 PM
oops, I don't have all my pics loaded. Look at my pics on my myspace profile.They have better descriptions anyway.
MySpace.com - Kevin - 34 - Male - PARIS, Texas - www.myspace.com/kevinberkley
That tank is from a 79 crew cab.They are still the narrow frame width like a cab/chassis or highboy.A regular 79 truck frame is 3 inches or so wider.I have another tank from a 80'ish van/ Bronco ?t is near identical to the one shown.You will need to rig a way to mount it if you don't have a donor truck crossmember and pan.I converted to a short bed so the saddle tanks won't fit mine.I know it is more money, but a tank/tool box combo is pretty attractive for ease of install and capacity.I wanted to put a topper on mine.
  #42 (permalink)
Old 04-29-2009, 05:08 PM
1974 Ford F-250
Just found out in another thread that the Bronco II tanks are metal - dang, there goes that as a backup
On to looking for another tank to fit. I can make mounts/filler neck for darn near anything so that is less of a big deal than finding one that physically fits in the truck. Frame widths are so narrow on these "highboys" that fitting something between the driveshaft and frame is tight (custom aluminum tank might be the answer here), and then the space for something under the bed, between the rear frame rails is tight.
Is that tank in the back of your crew plastic? I bet one would be hard to find, but it looks like a cool deal.
As for the in-bed tanks or tool boxes - I have never been a fan of those. They just never look "good" to me.
__________________
1970 Ford F250
  #43 (permalink)
Old 04-29-2009, 05:42 PM
Yes the one in that pic is plastic as well as the "van" tank. I think the full size bronco frame is wider..? Both tanks I have will fit the narrow frame.
  #44 (permalink)
Old 04-29-2009, 06:02 PM
1974 Ford F-250
Good to know - thanks!
__________________
1970 Ford F250
  #45 (permalink)
Old 05-06-2009, 02:45 PM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
I was doing a search on this subject as I just picked up a 38 gal tank for cheap. I read that the spectra premium tanks are ni-tern (sp) steel which contains no zinc making them safe for diesel. They have the appearance of a galvanized tank because they are dipped in nickel. You may want to do some research of your own but just thought I'd let you know your idea may not be dead.
__________________
2001 F-250 7.3L Ext. Cab, SB 4X4, MBRP 4in, DIY intake, autometer pillar gauges, DP F5 tuner (40,80 and 120), ride-rite air springs, 08 Diff. cover.
1977 F-250 5.9L Cummins Nv4500 (Work in progress)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
