I noticed the editing thing. I tend to do that a bit as well as I often re-read my post and add more info or fix spelling/gramatical errors.
Thanks for the cap info - I'll see what I can find. Too bad I am just now getting to this as I just a week ago bought and put on the Alfa the same cap that I will be taking off the crew now. Oh well - I guess I will now have a spare cap for the Alfa
I'm not sure if Theodore Robbins has the old parts books either, but it has been a while since I've paid the counter a visit - maybe I'll go say hi
__________________ Have you flown a ford lately? 1938 Ford Pickup = hot rod
1970 Ford F250 long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cabthread in "motor swap" forum 1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
If you do go, say hello to Milan (the parts manager) for me. He's been there for over 25 years.
We used to work together at Crenshaw Motors.
__________________ Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
Ok - now that I've got the vent figured out - here's pics of the tank as it sits now. It looks like I'll just get some barb fittings to run 1/2" hose and be done with it...
Stock tank (don't mind the seatbelt - it's just up there to keep it out of the way for now)
Stock/current fitting for vent line to charcoal canister
Stock/current fitting for supply line
Yea, you're definitely not going to want to use that canister line, Notice the Orfice crimp!
Then you are going to use a vented cap?
When you get it running, keep an eye on the pressure/vacuum in the tank, make sure your venting enough.
The line the you are connecting your seat belt to... Is that the filler vent?
If all else fails, You just might get away with T'ing that, the problem I see with that is the vent should go up, no place to go!
Guess you could run it up the B pillar then down and out.
Yup - getting a 90* to barb for 1/2" rubber line.
Quote:
That's the plan as of now.
Yes that is what I was calling the "fill vent". I'm not 100% sure that's what it is, but that is what it looks like. It just runs from the base of the fill neck to the top of the tank.
I was thinking possibly a T in that as a secondary or "extra help just in case" vent. If I did I would loop up above the tank a bit and then down and out, as like you pointed out - without cutting a hole in the body there is no where to go up and out.
Side thought here though. An idea came to me mid thought while typing the above...
What if I T'ed a 1/4" line or so off that filler vent and ran it out the rubber gasket/sleeve that the fill neck comes in? I haven't had the tank out to see how much room/play I have in that area, but I will look. That keeps it going up and out, while not cutting a new hole in the body or being some super long run.
Cool, Whats next!
A whole lot
I've got a bunch to keep welding on the motor mounts and cross member, and then I'm starting the steering box swap.
I am also planning on taking the tank out and getting it clean and the lines started.
The next thing that will need some "thinking" is the clutch master (didn't we just go voer this), throttle cable and cable for shut off valve.
Would it be visible from the outside by the filler cap?
Don't remember what they looked like.
hopefully not - and it would all depend on how clean my work is... My goal would be to not see it.
On the cab tanks for these trucks there is a rubber boot that goes around the fill neck where it exits the cab. I would try to melt/cut a slightly undersized hole in the boot and then slide the 1/4" breather hose in the hole. If I could make it work the way I picture it in my head all you would see from the outside (if you got up close and looked) is a hole in the boot - which would be the ID of the hose.
Clear as mud?
From what I have read diesel fuel will attack the galvanizing inside the tank.It makes it release from the metal and get into your fuel system.I would research some more.I ended up using a poly tank on mine behind the axle.Of course filter before lift pump,finer after lift to injection pump.It would be nice to have some way to drain water off the tank as well.
Thanks for the input. That is something I had not heard. I have a spare 36 gal poly tank here. I was kind of saving it as a spare for the race truck, but maybe I'll use it...
That is what I was thinking they looked like.
(Gee, My memory does still work -*- Sometimes!)
I suspect the vented cap will be enough though, you really only have to vent what the motor eats. I would wait on this till you find out if it's needed.
Hmm, Interesting, Never heard of that, The tank can be coated pretty inexpensively. Had a 150 gal tank done and it cost like 45 bux, but that was a few years ago! It was a steel tank and done do to rust.
I have heard the cheaper coatings (Eastwood, etc.) come off and eat carbs, etc. I have never heard about diesel fuel doing wonders on the galvanization though.
As for coating the tank - the good stuff lasts forever. Costs $250 or so though
The one I had done had lifetime warranty... They filled the tank with stones (abrasive stone) and tumbled it, cleaned it, added an acidic etcher, tumbled it, dumped it, added a neutralizer, tumbled it, dumped it, added the liner, tumbled it, dumped the excess and let it cure... It was a white rubber like stuff.
But like I said, that was a few years ago, it was done in Pittsburg Ca. by a radiator/muffler shop.
And I have no clue how well it held up, it worked fine for the years I had it, stopped the rust problem.
I went to the Vatozone and had them cross reference the part # that NumberDummy had. It turns out to be the same part that I just bought for my alfa romeo project.
Since I had one I grabbed it off the alfa and tried to put it on the crew cab - but no luck. It would not go on. Pics below show why...
New cap is one I bought for the alfa - old one is what was on the crew
The "neck" (for lack of a better term) on the new cap is to short to engage the fill neck on the truck - as seen in the last pic above.
Neither of these caps look "vented" to me, but that is very possibly just my untrained eye.
Seeing as both caps look the same aside from the length of the part that locks into the fill neck, it is very possible the one already on the crew is vented. Therefore I think I'm just going to leave it.
Any comments or advice?
Last - here is what I believe is the "vent" on the fuel cap. Not sure how this is a "vent" as if the seal works I'm not sure how it could get in/out
Sorry for the crappy pic - flash didn't help things
that looks different then my gas caps, i dont have that part in the center. and i konw that mine is not vented because my tank can build presher.
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
