"California hop"
Received 4,119 Likes
on
Don't drive there. Could be the road surface is wash boarded and with the stiff suspension you have on your truck makes it feel *****. Try adding some weight and see if that makes a difference or go to a dealer that has a similar truck and suspension setup to see if it drives the same. I had a similar experience with a 1/2 ton chevy, adding weight made all the difference, worth a try.
You still have the orginal factory shocks? If so they are probably shot. You can't really tell how bad they are while they are still on the truck. The best way to tell is take one of them off and if you can easily compress it then look into getting new ones.
Good shocks should be able to eliminate or greatly dampen bounce from the springs.
Yeah, mine was bad too. I could hardly drive it empty on some of the So Cal freeways. I installed Bilsteins and it is a lot better. I still get some hop, but I haven't seen anything that would make me slow down like it was before.
I had the FX4 shocks, and about 50k miles on them. If I had taken them off and tested them by hand I would NOT have believed they were bad. They had plenty of gas charge and were as stiff as the Bilsteins. So the point is, I don't think you can tell anything by taking them off. Just get some Bilsteins on faith.
I think that's about all you can do, other than putting a couple of sandbags in the back.
I just did a long trip to Colorado and back. I have new Bilsteins on and even with them, and 13k worth of loaded stock trailer, parts of I-80 out through Nevada and Utah still jarred my kidneys out. I swear about 3 minutes of that road and both me and Dad suddenly had to stop and pee.
Honestly I dunno if there is much you can do when the road just sucks that bad.
That's exactly the problem here. They pour the concrete in patchwork fashion, 12' sections I think, and it slumps in the center of each panel. That sets up a harmonic bounce at certain speeds, which seems to be right around 65mph.
Ford Motor Company is aware of this issue and has responded by offering a new warranty named the "SDTOKT" Program, which stands for "Super Duty Owner's Kidney Transplant" Program! The roadside assistance portion of the warranty is really special... they bring "Depends" diapers in your choice of men's or women's sizes!
Greywolf
45
08-15-2011 02:05 AM
