Best cold air intake and exhaust.
#31
Depends on when, but we will let them idle after a hard tow, or a hard run to allow the turbo to cool off. By letting it idle it allows the oil to circulate and not heat soak into the turbo.
#32
#33
Does a diesel use a lot of fuel on start up? To justify not turning it off and on..off and on. I am not a mechanical engineer or anything but it seems the nature of the diesel engine is to run continuously similar to jets or tractor trailers. I know growing up on the farm, dad wouldn't let us kill and start ....do that to the tractors. Once you start em, just let em keep running
#35
If your pickup is a 2005, the stock system was a donaldson powercore filter. It's an excellent system, and you can often find them on e-bay dirt cheap.
#36
There are a number of reasons to idle a diesel truck.
1. To warm up the engine in the morning. The most wear and tear on an engine is when the pistons, rings, oil are cold, there is more friction and stress. Idling also allows warm oil to circulate through Turbo before accelerating.
2. Idling before shut down, this allows the engine to cool down evenly, preventing warping, lockups, and oil build ups. It protects the Turbo and other engine components.
3. Idling between uses, diesel engines are much harder to start, so each start affects the battery and starter life.
4. During startups and shut downs engine components are rotating and moving without oil during shut down. Engine components rotating and moving without oil during startup.
#37
#38
I believe I can say all the aftermarket systems are good. (yes, even the K&N)
That said, what do you want?
Are you on a budget?
Is noise a concern?
Does it have to look good?
In my opinion.
The 6637 is the best, cheap intake you can get. Some folks don't like the looks or the turbo noise associated with it, but it does the job just fine. If looks and noise are a concern, then this one is not for you.
S&B is a step up certainly! Looks real nice. And is quieter than the above mentioned 6637.
AIS is the most quiet one out there today. Flows real good especially if you're just running stock injectors and turbo. A chip or programmer will not affect its performance, it will handle the air necessary. If you go bigger injectors and turbo, then the S&B or AFE may be a better option.
I do not have any experience with the AFE on a 7.3, but I do have one on a 6.4, and it does quite well.
All of them are great with getting clean air to your motor, which is what you want.
Is noise a concern?
In my opinion.
#39
#40
Is noise a concern?
In my opinion.
Is noise a concern?
In my opinion.
For exhaust, 4-inch from Turbo back is more than adequate unless you're going to be pumping some really serious HP's... like over 450 HP.
As for brands, I see more comments about satisfaction for MBRP systems, but Diamond Eye, Magnaflow, and Silverline also get good reports.
The aluminized systems are obviously much cheaper...is the stainless system worth the extra cost?
#41
That all depends on where you are located and what you will be using the truck for. If you live in the rust belt or hit the beach a lot then a SS should last a lot longer, if not an aluminzed one should work just fine. I have an aluminized one day ready to go on my truck, no concerns about road salt here, and I don't plan on taking this heavy beast on the beach......
#42
#43
#44
I love the 6637 filters. The sound is amazing IMO. You get on it from a stop, get it to about 3rd gear, then let it off. The suction sound is addicting.
As far as exhaust, mine was modified before I bought it. I believe it is a 3" or 4" straight pipe to about a 6" stack, sounds like a friggin semi. Its awesome. Im kinda throwing the idea around of running a normal tailpipe to behind the rear tire, but I dont really want a hole in the bed. But with it right behind the cab you gotta kind of talk louder, but Im usually on my own. The stack does look sweet though IMO.
#45
Best Cold Air Intake for Ford 7.3 Powerstroke 1998-2003
It sounds like the 6637 is definitely the more aggressive sounding filter.
