Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 04-10-2009, 10:33 PM
MikeyLikesIt's Avatar
MikeyLikesIt MikeyLikesIt is offline
Garage is empty, add now
MikeyLikesIt is starting off with a positive reputation.
Exclamation Piece of crap!!!!!!!
STUPID DAM TRUCK, SON OF A B****!!!!!
I PRIMED ALL THE LIFTERS THEN INSTALLED THEM, THEN I PRIMED THE MOTOR BY RUNNING A DRILL ON THE OIL PUMP, WHILE TURNING THE MOTOR BY HAND ON THE ENGINE STAND MIND YOU. ADJUSTED VALVES BEFOR AND AFTER JUST TO BE SURE. THEN DID THE 25 MIN BRAKE IN AND CHECKED THE VAVLES AGAIN, DAM IT F******** . 5 LIFTERS ARE SOFT. CRAP WHAT THE HELL MAN. 5 BAD LIFTERS. WHAT NOW.
__________________
http://www.ford-trucks.com/forums/pi...523451&thumb=11976 hi-boy 468 Cubic IN. Factory paint. No lift.
  #2 (permalink)
Old 04-10-2009, 10:44 PM
william_04_x's Avatar
william_04_x william_04_x is online now
Interstate Menace
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Piece of crap!!!!!!! byMikeyLikesIt
with the title and your username, i had to look...
sounds like you did everything right...did you soak the lifters overnight?
__________________
04 EB X w/ 03 6.0l PSD Tunes by Eric at Innovative, ARPs, ITP RR, 4" SS MBRP, Custom Dual HFCMs, ZEX N2O w/custom progressive controls, DC Power Polished 190, Riffraff IC Boots in Red, DieselSite Coolant Filter, DiPricol Boost EGT Fuel Pressure Trans Temp, Michelin LTX MS2, Toyo Proxies, M&H Racemasters, Hellwig, Bilsteins, Firestone Ride Rites, ViAir 480C compressor/3 gal tank, Siege horns, SEIC/High Idle Mod, V1 w/custom LEDs, 55wt 5K HL's, 35wt 5K FL, KC 121 130wt DL's, Clarion NX702, Alpine Amps and Subs.
  #3 (permalink)
Old 04-10-2009, 10:54 PM
ya i eaven primed them after soaked them, then i turned the motor over by had while running a drill on the oil pump till the oil started comimg up through the push rods be for i put it all back together. and they where all hard before i fired it up. guess i just got a bad bath huh?
__________________
  #4 (permalink)
Old 04-10-2009, 11:32 PM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
wmjoe1953 is gaining momentum as a positive member of FTE.wmjoe1953 is gaining momentum as a positive member of FTE.
Well, it sounds like either too much preload, or lack of break in lube on the lifters. Sorry to hear that. It's not very often that a set of lifters goes out at break in, unless something wasn't done quite right. I know there were a few companies experiencing bad batches of metals back in the 90's, but that issue has been dealt with. How are you seting your preload?
__________________
Hi, my name is Joe, and I am a 53-56 Ford truck addict.
My photos are kept in photobucket. Feel free to check it out: http://s248.photobucket.com/user/wmj...ibrary/?page=0
  #5 (permalink)
Old 04-10-2009, 11:50 PM
when i set the lash i followed comp cams instructions:just as the exaust starts to open adjust the intake, let exaust open close and adust exaust. on each cyl. then i went with 3/4 turn and locked the rocker. to prime th lifters i soaked them for a day in oil, then pushed then with a rod tho make sure they primed and then installed them, while on the stand i set the valves then ran the oil pump with the drill and turned the motor over by hand till the oil came out of the top of the rods. kept going for couple min just to be sure. let sit over night. then checked lifters. seemed to keep prime. added break in oil sup. comps own brand. then checked the valves next day just to be precise and 5 lifters are soft /not holding there prime.
__________________
  #6 (permalink)
Old 04-11-2009, 12:04 AM
bump........................
__________________
  #7 (permalink)
Old 04-11-2009, 12:14 AM
Old93junk's Avatar
Old93junk Old93junk is online now
Old, tired and grouchy
1993 Ford F-250
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Crap!!.....Bad lifters in the first place?
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
  #8 (permalink)
Old 04-11-2009, 12:17 AM
ya brand new lifters. what the hell? im gonna call firs thing monday morning. see what i gotta do now. what do ya think? ive never seen this happen, how bout u guys??
__________________
  #9 (permalink)
Old 04-11-2009, 12:20 AM
im just so damn frustated with this. ive never had this happen.
__________________
  #10 (permalink)
Old 04-11-2009, 12:22 AM
Old93junk's Avatar
1993 Ford F-250
Quote:
No, you just had to go and be original.....Joe or Don may be able to shed some light, I have NEVER encountered this.
__________________
Dave
  #11 (permalink)
Old 04-11-2009, 03:42 PM
wmjoe1953's Avatar
You say you added oil supplement. Did you cover the ntire cam and the bottom of the lifters with the break in compound? When installing the cam, you NEED to wipe all the lobes with break in compound, install it, and then cover the bottoms of every lifter with break in compound. You CANNOT just add break in supplement to the engine oil. You will kill the cam and lifters every time, if you don't cover them during install. Unless I am missing something, according to your description, that seems to be what went wrong. Get back to me Mike, and we can figure this thing out. I just finished building a 12 sec Sportman car yesterday..... started with an empty block at 8:30 a.m, assembled the rotating assembly, by 9:30.....went out on an accident call, got back by 10:45... finsished assembling the entire engine by 2:00, while taking a hour lunch, and had the car running by 5:00.
__________________
  #12 (permalink)
Old 04-11-2009, 05:22 PM
ya i did put that on it and on the lifters at assembly.
__________________
  #13 (permalink)
Old 04-11-2009, 06:09 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
What brand of lifters did you use?
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #14 (permalink)
Old 04-12-2009, 12:36 AM
it was comp cam and lifter set. but, i found out that they make a premium line saposed to be a no bleed/ or guaranteed not to bleed out and go soft. so i ordered that set to replace the ones they sent, then ill send the other ones that came in the kit back.
__________________
  #15 (permalink)
Old 04-12-2009, 09:26 AM
1935 Ford pickup
I've had problems with Comp Cams lifters before. I prefer Crane, or Isky cams myself..................
__________________
Tags
crap, escape, ford, piece
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
