Actual Horsepower and Torque Question?? - Ford Truck Enthusiasts Forums
Old 04-10-2009, 10:31 PM
Honestbest333 Honestbest333 is offline
Honestbest333 is starting off with a positive reputation.
I've got a 94 350 with a 7.3 non turbo in it. Does anyone know the actual horsepower and torque of this engine?
Old 04-10-2009, 10:33 PM
dyoung14's Avatar
dyoung14 dyoung14 is offline
dyoung14 is starting off with a positive reputation.
Quote:
185hp and 365 ftlbs of torque,
Old 04-10-2009, 10:48 PM
Thanks! Is it hard to get 400 foot pounds of torque out of this engine with out killing the fuel mileage?
If so, how?
Old 04-10-2009, 10:59 PM
dyoung14's Avatar
if the fuel system is in good shape it should be no problem to get 250 hp and somewere close to 500 ftlbs torque buy adding a turbocharger to the engine, and your fuel economy depends on how much you turn up the injetion pump or how much you stick your foot into it. but dont turn your injection pump up unless you buy a pyrometer!!! cause to much fuel can melt the engine.
1dieselman's Avatar
1dieselman 1dieselman is offline
1dieselman is starting off with a positive reputation.
The best power builder is going to be turbocharge it.
Old 04-11-2009, 12:19 AM
George D.'s Avatar
George D. George D. is offline
George D. is starting off with a positive reputation.
The factory turbo 7.3s are rated at 190 hp at 3000rpm and 385ftlbs at 1400rpm and the naturaly asperated are 338ftlbs 88-92 and 358ftlbs 92.5 and up and 185hp all years these numbers are striaght from the ford turbo update manual. Also the N/A motors losses 3% hp for every 1,000 feet ellivation above sea level where the turbo'd engines maintain 190hp at ellivation. 500ftlbs is achiveable with the ATS turbo kit or the ATS down pipe upgrade on the factory turbo and some IP tuning.
Old 04-11-2009, 04:39 PM
Hellonwheels's Avatar
Hellonwheels Hellonwheels is offline
Hellonwheels is starting off with a positive reputation.
y are the older 7.3s lacking 20 lbft torque relative to the 92.5 and up
Old 04-11-2009, 09:12 PM
George D.'s Avatar
Diffrent injectors and injection pump calibration.
Old 04-11-2009, 11:01 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
So if a person was buying, Pump and Injectors, ordering a 92.5 up would be the choice... Regardless of what year you have (Turbo or NA)?
Of course if it's a NA just turn it down a bit if needed. (until ya wise up and get a turbo)
I realize bigger is not always better, thats why I ask.
Not buying, Just curious ...
-Enjoy
fh : )_~
Old 04-11-2009, 11:14 PM
George D.'s Avatar
If you have the Na just go with the E code injectors and matching pump. the only diffrence I'm aware of in the stock injectrs is the crack presure and the pumps are calibrated to work with that crack pressure. also i belive the advance curves varie in the diffrent calibrations. I wouldn't run the Turbo pump on the N/A motor since it has an advance and fule curve disigned for A turboed engine. If I were building a hot N/A motor I might run G code injectors with the 93 IP and turn the timming up a bit to match the injectors.
Of coures if you needed injectors and a pump and were definatly going to get a turbo in the near future then you could detune the turbo pump to work with the N/A motor.
Old 04-11-2009, 11:54 PM
dyoung14's Avatar
i herd its best to use turbo injectors with a turbo pump, and n/a injectors with a n/a pump, because of them being calibrated for each other
Old 04-12-2009, 12:32 AM
George D.'s Avatar
Yeah thats true.
More horsepower/torque 351W 96 CooperF350 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 09-21-2014 01:49 AM
360 and 390 Horsepower and torque? 401477534 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 23 04-05-2011 12:45 PM
Horsepower and torque for 390? Tylersgrave 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-15-2011 06:55 PM
Actual Horsepower and Torque 1994 F-350 Honestbest333 New Member Introductions 4 04-17-2009 04:50 PM
trans rating? mad scientist:p Clutch, Transmission, Differential, Axle & Transfer Case 9 03-23-2006 03:24 PM
Tags
04, 1986, 69, 73, 73l, 97, f250, horsepower, hp, idi, injector, kit, pump, torque, turbo, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
