1980 Ford F150 Ranger Lariat - Page 9 - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #121
Old 01-22-2013, 08:15 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
looking great Shaun love the build up.
Trav
  #122
Old 01-23-2013, 02:49 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
Thanks guys!
  #123
Old 04-19-2013, 08:46 PM
'86 F150's Avatar
'86 F150 '86 F150 is offline
'86 F150 is gaining momentum as a positive member of FTE.'86 F150 is gaining momentum as a positive member of FTE.
Any updates? Awesome buildup. Truck looks great.
  #124
Old 04-20-2013, 12:23 AM
Unfortunately, I don't have anything else to add.
My Ranger has been my primary focus lately, and I still have some more work to do on it. It too may be getting a 4x4 swap soon, so I'm not sure when I'll be able to get back onto the F150.
Right now, the exterior and interior of the F150 are done. All that's really left is to rebuild everything on the chassis and fix the rust. Of course, those are the most expensive things to fix.
I'm hoping the F150 will be done before I turn 25. I'm close to 21 now, so that gives me four years to figure something out. I picked up the truck when I was 15, so it would be nice to have it going by the 10 year "anniversary".
  #125
Old 04-20-2013, 08:28 AM
'86 F150's Avatar
I know how that goes. I started collecting parts for a model T hot rod project when I was about 13 and haven't really got it any farther done now then I did then. I have almost all the parts to put it together, but still looking for a couple things. Im 21 now. Sometime hopefully in the near future I'll get to working on it.
  #126
Old 05-25-2013, 05:57 PM
GMCPic GMCPic is offline
GMCPic is starting off with a positive reputation.
Hey Fordzill80 great job this an old post..but I was wondering if you could take some pix of engine compartment without air cleaner? I have a 1980 Custom 4X4 4.9l and need to connect up all the missing vacuum lines for ca SMOG TEST.
  #127
Old 05-19-2014, 10:55 PM
One year later.......UPDATE!
Washed her!
Also, started working on collecting parts for my 400. New water pump, new belts, new accessory bolts, etc.
  #128
Old 06-15-2014, 09:52 PM
New intake, painted a few more accessory brackets, new thermostat housing, new distributor, NOS Ford throttle cable bracket, and probably some other things I'm forgetting.
Picture is missing the distributor, and I also traded the chrome valve covers for factory Ford valve covers for a more stock look.
  #129
Old 07-22-2014, 09:04 PM
Some more updates from the last month.
Sold the 92-96 saw blade wheels and bought a set of the factory 77-81 slotted mags:
  #130
Old 09-10-2014, 09:07 PM
The truck originally came with an in-bed spare tire carrier, as evidenced by the holes drilled into the bedside. A previous owner removed it, but a fellow forum member sent me one from his old truck.
Also, truck finally came back down on all four wheels.
  #131
Old 09-25-2014, 08:26 PM
All washed up.
  #132
Old 09-25-2014, 08:33 PM
fordman75 fordman75 is online now
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Looks Great!
  #133
Old 10-07-2014, 08:56 PM
Thanks Ted!
  #134
Old 10-22-2015, 10:06 AM
1980 Ford F-250's Avatar
1980 Ford F-250 1980 Ford F-250 is offline
1980 Ford F-250 is starting off with a positive reputation.
Get that motor in yet? Looking good!
  #135
Old 06-11-2016, 10:01 PM
Haven't really updated this in a couple of years, but I do still have the truck, and I'm finally in a place where I can start some more work on it.
Biggest update is that I decided to go with a different wheel setup for everyday driving. I'll be keeping the factory slot mags for shows to make the truck look more original.
I also installed some new tail lights to replace the cracked and broken ones from 1980.
Here's how it currently sits.
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 06:34 PM
78/79 RestoMod Raleigh1 1978 - 1996 Big Bronco 682 03-18-2016 02:29 PM
MY '03 EXCURSION...WITH '08 FRONTEND. DaXman Excursion - King of SUVs 30 07-03-2015 06:38 PM
Never seen ford has panel ! Super Econoline 1973 - 1979 F-100 & Larger F-Series Trucks 24 11-04-2012 06:09 PM
Picked up new Door Panels. Fordzilla80 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 31 03-27-2010 12:54 AM
Tags
1980, 1999, 9inch, automatic, c6, custom, f100, find, ford, interiors, lenght, pics, rear, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
