Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
1980 Ford F150 Ranger Lariat
Old 07-23-2012, 09:14 PM
FORD COASTIE's Avatar
FORD COASTIE
FORD COASTIE is online now
Supporter of Patriotism
Received 2,363 Likes on 1,709 Posts
That original Ford blue looks nice! Good looking truck you have there! I have always liked that body style.
  #107
Old 07-23-2012, 10:11 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Thanks!
  #108
Old 08-12-2012, 11:03 PM
Fordzilla80
Well, I finally picked up a transmission for the F150.
It's a C6 4x4 trans with the big block bell housing. It also has the reinforced casing. I have some scraping and cleaning to do before I can find the cast dates and figure out what year it is. Eventually it will get a complete rebuild with a tiny shift kit for towing, and some off-road use.
  #109
Old 08-16-2012, 10:52 PM
Alex_4.2L's Avatar
Alex_4.2L
Alex_4.2L is offline
Such a cool build thanks for posting it.
  #110
Old 08-16-2012, 11:29 PM
Fordzilla80
No problem! I'm glad you enjoyed it!
I cleaned up the transmission a little bit, so that my hands wouldn't turn black every time I touched it.
  #111
Old 09-24-2012, 07:41 PM
Fordzilla80
Well, I've made some small yet important progress.
First off, I removed the entire front axle. I took it back down to bare metal, primed, and then repainted everything satin black. I finally also picked up the correct 1980-1984 steering knuckles to replace the 1995 knuckles I was running.
While I had the axle out, I decided to add the Handling Package to the truck. This meant that my single shock towers would have to be swapped out for dual shock towers. So I knocked out all the rivets from the towers, and then re-installed the towers with bolts. Eventually I will find new dual shock towers, and will simply unbolt the single shock towers and install the dual shock towers.
I also picked up a New Process 208F transfer case. This now gives me a complete drive-train for the F150 once again.
  #112
Old 11-07-2012, 04:07 PM
beefa270's Avatar
beefa270
beefa270 is offline
Looks great !!!
  #113
Old 11-07-2012, 08:41 PM
Fordzilla80
Thanks!
While I'm here, I have some small updates.
Finally added carpet to the map boxes.
Bought some New Old Stock parts including a clear park light, black slide lock assembly, and the correct 1980-1981 NP208 shift ****.
And finally, I also picked up a set of the 1980 Ford Shop Manuals.
  #114
Old 11-08-2012, 07:00 AM
19fifty4's Avatar
19fifty4
19fifty4 is offline
Thanks for the updated pics. Looking good.
  #115
Old 12-08-2012, 11:19 PM
Country705's Avatar
Country705
Country705 is offline
keep up the good work! nice project
  #116
Old 12-09-2012, 05:56 PM
Fordzilla80
Thanks!
  #117
Old 01-08-2013, 12:29 AM
Dane Udelhofen's Avatar
Dane Udelhofen
Dane Udelhofen is offline
hey I got a f250 XLT and I wanted to know what size my speakers are..??
  #118
Old 01-19-2013, 09:32 PM
Fordzilla80
Recently I picked up a set of the 1980-1982 Dual Position Mirror arms, as well as the correct 1980-1982 mirror heads.
I also ended up going back to the slide lock setup.
And the rest of the interior.
  #119
Old 01-22-2013, 02:12 AM
77Quadravan's Avatar
77Quadravan
77Quadravan is offline
Awesome build up man!
  #120
Old 01-22-2013, 07:30 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Keep up the good work Shaun.
Quick Reply: 1980 Ford F150 Ranger Lariat
