Hot drum brake - again! - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-10-2009, 07:57 PM
billj6 billj6 is offline
billj6 is starting off with a positive reputation.
'99 Ranger xlt 3.0 ltr. 4x2 105,000 mi.
Just installed rear brakes and spring kit. Left side only needed a self-adjuster kit. I cleaned everything up inside and put dabs of grease on the friction points. I also bled them both, then sailed through Pa. state inspection. The left rear drum is always very hot when I get home so that you can't hold your hand on it and the right is just warm. (I live at the bottom of a long hill). This happened a few years ago when I last replaced them. You can't feel it when braking, but I think the left remains on for a time after the brakes are released. Can't figure out why this would happen. Can that equalizer valve on the rear brake line go haywire? The bleeding went smoothly on both wheels.
Old 04-10-2009, 08:33 PM
antony25 antony25 is offline
antony25 is starting off with a positive reputation.
make sure the wheel cylinder pistons move freely in the cylinders. also check the parking brake cables if you use it.
Old 04-11-2009, 07:47 AM
drum brake
I always use the E brake just so it will move freely. I replaced both wheel cylinders last time I did brakes about 25,000 miles ago and one was bad then but I don't remember which. May have to take the left one apart and check for scoring.
Old 04-11-2009, 04:30 PM
mfp4073's Avatar
mfp4073 mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.mfp4073 is gaining momentum as a positive member of FTE.
Are the drums grabby?
Old 04-12-2009, 10:58 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
Had same issue with mine and it was the section of emergency brake cable that goes into left rear drum. It had rust inside the housing that no ammount of lubrication would free up. Replaced cable and no more problems
Old 04-12-2009, 11:58 AM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
Yeah, I put new cables on my 88 F150 about 2 years ago. I use the ebrake constantly (its a stick) and the left one is starting to stick. I guess its just the nature of living in MN
72 F100 rear brake question coppertales 1967 - 1972 F-100 & Larger F-Series Trucks 13 07-31-2015 09:38 AM
Rear drum brakes not working berndt Ranger & B-Series 11 11-03-2014 06:40 AM
Right Rear Drum Brake Tightening Biggone 1987 - 1996 F150 & Larger F-Series Trucks 4 10-12-2014 12:22 PM
Rear wheel issue lordphantom Ranger & B-Series 9 03-17-2014 09:01 PM
Brake drum does not go on all the way. Sycostang67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 04-25-2013 10:11 PM
Tags
1999, brake, brakes, drum, drums, ford, hot, left, ranger, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
