MotorCraft Spark Plugs - Ford Truck Enthusiasts Forums
Old 04-10-2009, 08:02 PM
Lariat#1 Lariat#1 is offline
Lariat#1 is starting off with a positive reputation.
I know this Motorcraft plug is NOS in most stores AWSF32PP, but if you know where to look you can still buy them. The OE replacement is AGSF32FM. Now, which is really the better spark plug ??? I`m put new plugs in my 97 4.6L V8 F150. The first is a double platinum, the second one is a fine wire single platinum. So which is better???
Lariat#1
Old 04-11-2009, 09:25 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Both are fine. Use whichever you can get. You probably will find the fine-wires far easier.
Old 04-12-2009, 12:07 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
The only difference is that the later number has more threads than the OEM number. Fits the same and still goes in the head the same difference, it's just a revision so that the plugs will also fit the mid 02 and up revised heads with 8 threads as well.
Use the AGSF32FM.
Old 04-12-2009, 12:56 PM
Ok but, AGSF32FM is a single platinum plug. Isn`t the double platinum better??
Lariat#1
Old 04-13-2009, 07:25 AM
Quote:
Lariat#1
No. For fine-wires, it doesn't matter.
Just use them.
Old 03-13-2014, 06:13 PM
RODBURNS RODBURNS is offline
RODBURNS is starting off with a positive reputation.
awsf32pp f4 4w8
ok, i bought these plugs for my 97 grand marquis 4.6 and never got them in, with 54 k i traded the car in nov 07 on my 07 f150 4.6
build date 06/08/07 norfolk plant
now ive got 50 k on the truck will these plugs work in my truck?
spark plugs 1999stroke 1967 - 1972 F-100 & Larger F-Series Trucks 2 01-31-2014 04:29 PM
Spark Plugs for Camper Special darren_palms 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-06-2013 10:52 PM
orig plugs in 03 F150 are different Jackedup07 1997 - 2003 F150 13 12-22-2012 03:17 PM
Which ignition components should be used on Aerostars Bear River Aerostar 4 02-18-2010 11:48 AM
Possible Plug Purchase Screw-Up....Help plaid311 1997 - 2003 F150 7 01-17-2006 09:31 AM
Tags
46, 46l, 54, awsf32pp, double, fine, ford, motorcraft, platinum, plug, plugs, spark, specifications, v8, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
