Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 05-07-2009, 03:53 PM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
1995 Ford F-150
My Garage
9.ford.5 is gaining momentum as a positive member of FTE.
ok i found a camera so heres some pics
heres my brackets with a nice coat of paint.
knuckles and tie rod...ill paint the knuckles when i do the ball joints and i think i need a new tie rod anyway so i wont bother with that.
this is th trac bar and you can see the two bends im taking out of it and shorten it about 4"
heres some random stuff i drew on a pic of the steering/drag link...its a basic mach up but its pretty close...in th pic you can barely see it but the circle is where it hits the x-member now but once i straighten it it will go right behind it, and the big box thing is where about the bracket will be so the trac bar can be 30" long and straight
__________________
PROJECT and DD---95 ford f150 4x4, 300 INLINE SIX!, 5speed, SAS, 4" lift, 35x13.50 ground hawgs (sooner or later)
PARKED---91 ford f150 lariat, 302 v8, auto, 2wd, rust
PARKED---92 ford f150 xl ext. cab short bed, dual tanks, 302 v8, auto, 2wd, LOUD!, very little rust!
  #47 (permalink)
Old 05-10-2009, 09:01 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
well i havent had time to get on here lately but an update even though it looks like im all alone in here now...friday while at work i used the 50 ton press to take the main bend out of that trac bar but i have a question do you think that trac bar will still be solid since i took out a factory bend? i will probably get a factory straight one anyway i was just wondering i did some planning on the trac bar braket and i can use a trac bar 30" in length so that should be fine since the drag measures 36" and i did the motor mounts on the truck friday night...
__________________
  #48 (permalink)
Old 05-10-2009, 09:07 PM
351slug's Avatar
351slug 351slug is offline
351slug is gaining momentum as a positive member of FTE.
Looking good, now I know why the bolt on kit from Jeffs Bronco cost so much.
  #49 (permalink)
Old 05-10-2009, 10:53 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
Quote:
hahaha i saw that on there and was like DAMN that would've been nice
i just went out and measured between 3 and 4* of forward caster i know its a little shy of what is recommended but this truck wont see a lot of highway/street use so i should be able to deal with the loss of handling.
__________________
  #50 (permalink)
Old 05-20-2009, 02:49 PM
351slug's Avatar
Is it done? How does it drive?
  #51 (permalink)
Old 05-20-2009, 09:48 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
well no...im still waiting for the arrival of parts... i decided to just build a trac bar and bracket, that will be last...i got the BJs out waiting for new ones...tie rod is good so im reusing it...gettin 78 rad arms brackets tomorrow so ill do those then to get a bit more caster...waiting on spindles... need a new cv shaft for the long side of the exle so i gotta find one tomorrow i guess...got new wheel joints installed in the short shaft and the long shaft will wait till it gets the new cv shaft obviosuly...waiting on ext. brake lines and caliper retainers and bolts to install calipers....properly measured caster and got 2* positive so not bad the 78 brackets should fix er up
and im out of parts and out of money so till payday next friday i wont have anything else
im so close but yet so far...
__________________
  #52 (permalink)
Old 05-22-2009, 04:55 AM
Bender99's Avatar
Bender99 Bender99 is offline
1991 Ford F-150
Bender99 is starting off with a positive reputation.
CV shafts and wheel joints?????????????????? I'm not sure where those parts are in a d44 lol
__________________
91 Shortbox F-150, 302, ZF 5 speed, Dana 44HD SAS, Dana 60 rear, 8'' Suspension Lift and 38'' TSL's.
Mustang lx, 2.3, 5 speed. Nothing cool except gas mileage!
  #53 (permalink)
Old 05-22-2009, 05:51 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is online now
1966Tbird is starting off with a positive reputation.
so do you think it's worth it? i've been wanting to swap a d60 under my truck for some time now but don't think i can put up with the month of downtime i'm going to be facing while i weld/hack/hammer everything in
__________________
89 F-150 leveling kit 33x12.5 BFG All-Terrains, Trick Flow Fast as Cast Heads, Comp Cams Gold Roller Rockers, Edelbrock RPM Air Gap Intake, Trick Fuel 750 Mechanical Secondary Carb, MSD E-Curve Distributor, Comp Cams 280hr Roller Cam, Comp Cams Roller Lifters, Comp Cams Valve Springs, Trick Flow Pushrods, DSS Main Girdle, ARP Bolts, Cometic Gaskets, Forged Pistons, 125 Shot of Nitrous, AOD, 3500 TCI Stall Converter, Lentech Street Terminator Valvebody, 4.56 Gears, Flowtech Headers, 2.5in Exhaust
  #54 (permalink)
Old 05-24-2009, 11:15 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
if i didnt have to order parts and serch for parts this would have been done a long time ago...if the parts are even available locally to me they are selling for 10x what they should be...so at the moment no....okay yeah its still worth it
and i cant remember whats its really called but by cv shafts i mean the small shaft that runs through the spindle on the end of both axle shafts i forgot what they were called?
and wheel joints are the u joints on the axle shafts thats what the parts store here calls em? ive also never heard of that name before but at least when i say that they dont ask me for engine size? LOL
all i have managed to do this weekend is change the wheel bearing on my dads splorer ha still havent seen hide nor hair of my parts
__________________
  #55 (permalink)
Old 05-25-2009, 09:14 PM
351slug's Avatar
Hey, keep up the good work. This post will come in to play for notes for me one day when I google search for solid axle swap.
  #56 (permalink)
Old 05-25-2009, 11:25 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
when you start researching your SAS go here FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs and READ MAN READ!...thats a whole board dedicated to SAS this build is on there too with a little more info because almost all of the people who replied to it have also completed the swap
called JBG today 3 times...they would not answer....is this normal for them?
im sick of waiting for parts its gettin on my nerves
__________________
  #57 (permalink)
Old 05-26-2009, 12:42 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
BUILD WILL RESUME FRIDAY
i located a pair of spindles at a small offroad shop in coaldale and they arent even stupid expensive so ill be picking those up friday along with my 78 rad arm brackets and possibly (hopefully) BJs
__________________
  #58 (permalink)
Old 05-29-2009, 02:20 AM
9.ford.5's Avatar
1995 Ford F-150
My Garage
okay i found BJs now...get this for the 2nd line BJs they are $160 for all 4 and for spicer top of line is about $320...so for now ill in cheapies and once those are toast ill throw in spicer so tomorrow or Saturday ill get back on the build and ill see if i cant kidnap the camera back again for ya
__________________
  #59 (permalink)
Old 05-29-2009, 02:47 AM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
I was looking at the dates on this thread, and the intention of this build was to be completed in a weekend. That was many moons ago.
Consider time and money, or money based on time, and a D60 could have been in there already.
Was this axle actually the right choice? How much dough do you have wrapped up in this build so far? Phone calls, trips to yards, time without said vehicle? Its all worth money right? I believe so. This is a million dollar SAS so far.
  #60 (permalink)
Old 05-29-2009, 01:08 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
i have two vehicles and its not even mud or hunting season yet so for now i couldnt care less about downtime with it...i know i wanted it done in a weekend then parts screwed me over and i said to hell with it...i could have had the labor done in a weekend if i had access to ALL my parts...like you bashed me for in the beginning...but i had problems with $$$ and access for parts...if it was a semi...then id be pissed cause id be losing money but im not losing anything so no big deal...and have there not been many WAAAYYYYYYY longer SASs done? and yes its very well worth the money...and no i did not want/need a d60 so why waste the extra time and money to do it
__________________
Tags
1991 , 4x4 , 60 , 79 , 92 , 95 , arm , arms , brackets , carrier , dana , f150 , ford , pics , radius , sas , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
