Integrated Wheel End Solenoid - Ford Truck Enthusiasts Forums
Old 04-10-2009, 12:08 PM
PJF150 PJF150 is offline
PJF150 is starting off with a positive reputation.
Hi Guys
Just wondering how involved is working on the IWED?Going from 4wd to 2wd shift on the fly after shifting,going a few miles down the road,I feel this grinding noise then CLUNK.Some say water can get into the system&mess the mechanism up.I have an 05 F150 STX 4.6 liter.I keep it in 2wd&no problems.Is this a big job to do?...Pete
Old 04-10-2009, 12:57 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
No, as long as you have done some work on your truck like brakes and such before and have most basic tools. Check out this thread.
http://www.ford-trucks.com/forums/83...ml#post7322441
Will not shift back to 2wd pcurtice 1987 - 1996 F150 & Larger F-Series Trucks 8 10-19-2016 09:26 PM
2002 f250 transfer case shifter operation BC7.3 Clutch, Transmission, Differential, Axle & Transfer Case 0 07-20-2014 06:10 PM
transfer case 4wd linkage apache12 1987 - 1996 F150 & Larger F-Series Trucks 7 04-11-2014 07:38 AM
shifting into and out of 4wd rioking 1987 - 1996 F150 & Larger F-Series Trucks 2 01-31-2011 05:03 PM
1997 F150 4WD Vacuum Solenoid Problem pjtessy 1997 - 2003 F150 4 06-15-2008 03:45 PM
Tags
05, 2005, click, end, ends, f150, ford, integrated, integratged, intergrated, noise, problems, solenoid, sound, wheel, wheelend
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
