Differential Gear Oil for Dana 50?
I'm changing the fluids in a 1995 F-250 I recently purchased and suctioned out the front differential- appears to be a somewhat lightweight gear oil. The manual gives a specification for the front differential but I can't figure out what it's supposed to be? 75W-90? The rear appears it should be 80/90 but I'm considering using synthetic would 75W-140 be OK in the rear? Thanks in advance.
Thanks- my manual doesn't actually specify which weight fluid to use in the front, it states to use "4X4 Gear Oil" and gives a Ford specifications number. A Google search and search of this site for that number (WSL-M2C191-A) didn't give me much (if any) more info on the weight of the oil to be used. The rear is specified as 80W-90. I ended up changing the front with semi-synthetic 75W-90. I decided not to change the rear, as it was topped off and the lube appeared very clean and light in color making me think the previous owner changed it recently.
Texas Bob
1999 to 2016 Super Duty
10-19-2019 12:12 AM
capriceragtop
08-27-2014 01:01 PM
Old Brown F250
09-16-2013 11:36 PM
littlechuck
10-06-2009 07:27 PM
