You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Put the truck on Matt's new dyno Tuesday. I didn't hit my goal ,but came pretty close.
Vids.
Dyno graph.
It put down 594 RWHP & 620 torque on 16 pounds of boost,15 degrees of timing. All motor no nitrous!
Look out 11.50,here I come.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
Man Phil, the truck sounds sweeeeeet bud. I am looking for a DYNO shop here in Southern MD. Anybody know of one in the vicinity?
With where I am at now, and after some mods, my 03 L should be in the low 12's if not high 11's now. It ran a 12.93 at 105 at 41 degrees F perfect weather and on a cool day outside.
Since then the mighty L has received:
1) An additional 607 CFM by adding an Accufab throttle body Single Blade. Stock was a twin blade w/1089 CFM and now 1696CFM
2) Additional 2lbs of boost with a pulley swap
3) K&N CAI
4) Magnaflow Cat Back
5) Valve body for the trans.
6) Diablo Tuner Programmer
SO...I think with this I should be in the 11's somehwere's rather easy.
Guys please let me know if you know of a DYNO shop. Headin to the swap meet 2-morrow if it doesn't get rained out again. Wheels to turn and rubber to burn!!
__________________
Shaun from MD
2009 F-150 Super Cab XL 4X4 4.6L 2Valve V8 My build thread.Added: N-Fab light bar, Rigid Industries LED lights,Rough Country hidden winch mount with Rough Country 9500lb winch. Up next: wheels and tires. Pending install Hell Bent Steel level kit. Big Bser number XO Slackmaster#5 Avid Winter Enthusiast!
Thanks guys and gal.
I could of hit 600 on the dyno but I'm running 2 less pounds of boost then before.
We'll see what she runs at the track first at 16 PSI,then if I cant hit the 11.50 I'll put the other pulley on for 18 PSI.
__________________
