Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-09-2009, 11:41 PM
artfd artfd is offline
Garage is empty, add now
artfd is starting off with a positive reputation.
Removing clutch slave cylinder
The clutch hydraulics on my 1983 F250 6.9L Diesel went out for the 2nd time in 26 years. This time I will fix it myself if I can. I took a closeup photo of my actual slave cylinder, shown here.
didn't help me much.
My copy of the 1983 Helm service manual tells how to remove the slave cylinder (p. 16-04-2) thus:
"4. Push the clutch slave cylinder rearward to disengage the two retaining tabs of the release cylinder from the retainer bracket and from the recess in the bell housing lugs and then slide forward to remove. Disengage the push rod from the release lever as the slave cylinder is removed."
The slave cylinder seems rigidly mounted against the bracket & doesn't move at all when I push it "rearward" The springy metal clip that holds the cylinder to the bracket is thick & strong looking compared to the cylinder. The only "engagement' of the end of the push rod with the release lever seems to be that it fits in a slight dimpling of the metal of the release lever. Is it attached any other way?
I'd appreciate any hints on how this can be removed by real people.
Also, the manual states "The clutch hydraulic system is serviced as a complete assembly and is pre-filled and bled. Individual components are not available." I have found no source for a complete assembly for my vehicle, just a list of individual components that need to be assembled, filled & bled. I take the complete assemblies are not longer being made for my 1983 model. If anyone knows otherwise, please let me know.
  #2 (permalink)
Old 04-10-2009, 01:15 AM
TourqueRise TourqueRise is offline
TourqueRise is starting off with a positive reputation.
With my slave on my zf 5 which looks the same as yours I just took a flat head screw driver and pried the slave bracket off the trans housing. Good luck
  #3 (permalink)
Old 04-10-2009, 01:44 AM
It looks like a flat head screw driver would work, but I appreciate hearing from someone who has done it before. The shop manual's instructions make no sense at all.
  #4 (permalink)
Old 04-10-2009, 06:41 AM
maxdiesel maxdiesel is offline
maxdiesel is starting off with a positive reputation.
Just wedge a flat blade screwdriver under the metal bracket and it will come right off
  #5 (permalink)
Old 04-10-2009, 08:19 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Yes, it basically slides out, just lift the retaining clip enough to slide it out, it really is that simple. The pushrod is held in by pressure into the dimple on the fork. The only thing holding the slave in place is that springy metal clip.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #6 (permalink)
Old 04-10-2009, 09:31 AM
Looks like your piston retaining straps are missing. You should bench bleed the new slave and switch over the line before you take the old slave off. If you don't you will have to bleed the whole thing which can be a real PIA
  #7 (permalink)
Old 04-10-2009, 11:59 AM
How do you bench bleed a new slave?
  #8 (permalink)
Old 04-10-2009, 12:29 PM
Find some clear tubing that you can wedge into the hole where the line from the truck would go. Then submerse the tubing in brake fluid and work the piston in and out until all the air is out. Then hook the retaining straps on. When you install it crack the bleeder so the piston will retract a bit as you slide it into the little cup that holds it on the transmission fork .
Tags
2001, clip, clutch, cyl, cylinder, diesel, f150, f250, ford, push, remove, retaining, rod, slave, threaded, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
