05 F150 not Starting
Starter terminal fatigue?
https://www.ford-trucks.com/tsb/full...p?tsb=06-19-14
My truck would seem like it had a bad battery or the starter wasn't catching at times.
Maybe we can find others that this TSB struck... and see what symptoms they had.
Jus' tossing out some ideas...
Rich, thanks for the info. I will check with the dealer to see how much this kit is. with only .4 hours of labor associated with this I'm thinking it will be a pretty simple thing to do.
But I have faith you two will find something similar about each other's problem ...
On to the Problem...
James, You mention changing relays earlier... which ones? (Sorry if you stated it sometime earlier)
Vegas123
78
12-07-2015 01:37 PM
BlueOvalDismantlers
46
10-15-2012 07:43 PM
Slankky
08-19-2012 02:02 PM
Julies Cool F1
16
06-19-2010 03:42 AM
