Do Escapes Have Keyless Entry? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 04-09-2009, 08:59 PM
giles45shop giles45shop is offline
giles45shop is starting off with a positive reputation.
I'm thinking about getting a used Escape as a commuter vehicle and for transporting all my dive gear on trips to the N FL caves. On handy feature I've found for divers is the keyless entry on my '07 F250 and '03 Expy.
Does the Escape have this option? I'm probably looking at an '05-'07 w/ 2.3 4 cyl/automatic.
Thanks,
John
Old 04-09-2009, 09:43 PM
YoGeorge YoGeorge is offline
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
Thanks,
John
Yes, it was standard on all trim levels from the Escape XLS on up. Keyless entry may have been standard on all Ford vehicles.
'05 and up is a great choice for a 4 cylinder model...the 2.3 is significantly better than the old 2.0 and all models have ABS as well.
Good luck,
George
Old 04-10-2009, 06:29 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
Our 08 mariner has keyless entry, I'm just not use to having it and never use it, but it's there. The 09's have a 2.5 duratec with a 170 hp and 170 foot lb's, a long with a 6-speed automatic. They just keep getting better and better. "O", and the V-6 now has 240 hp and a 6-speed auto. Thats more ponies than the stock 5.0 mustang GT's had.
Old 04-10-2009, 09:58 AM
JFUSION JFUSION is offline
JFUSION is starting off with a positive reputation.
are you looking for the fob activated version or the one that is mounted on the exterior of the driver's door ?. The door mounted version was not standard on past models but it was an option. The fob activated version was standard on past models. If you find a model that doesn't have either system, they are both available as an accessory from your Ford dealer.
Old 04-10-2009, 10:22 AM
Quote:
Good point. When I said that all Escapes had keyless, I meant via key fobs. If you want the combination pad on the driver's door, I believe that this was an option on the XLT models, probably not available on the XLS, and probably standard on the Limited.
The keypad is really cool if you want to leave your keys under the mat while swimming or mountain biking or something.
George
Old 04-10-2009, 11:29 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman NewEnglandHerdsman is offline
Moderatee...
NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.
FWIW, our 2003 Limited has no keypad....
Old 04-10-2009, 11:46 AM
Quote:
Interesting....I just checked my 2007 Escape brochure (oldest one I have) and the XLT Sport and the Limited both have the external keypad standard. No idea when they made this standard, though.
But actually, if the OP is looking for a 4 cyl Escape, the Limiteds were all V6's anyway until 2009 (or was it 2008?) And the XLT Sport was probably V6 only as well.
George
Old 04-10-2009, 03:31 PM
Thanks for all the inputs! I was asking about the door keypad version, so I don't have to carry a key when diving. I suspected it wasn't standard, since I've been casually looking at Escapes in the parking lots, and hadn't seen one.
At least I know there may be some out there. It's not a deal breaker as I can use a hide-a-key or similar, just a nice feature.
Thanks,
John
Old 04-10-2009, 05:35 PM
Looks like about $75 gets ya one...
Looks like you can get an OEM accessory one, probably uses a little flat battery like the key fob remotes:
Ford Escape Keyless Entry Keypad at Dealerfit.com
Old 04-10-2009, 06:16 PM
Yeah, our merc has the key pad thingy on the door.
Old 04-10-2009, 06:21 PM
they are an easy accessory to add, they are held on with adhesive, no drilling, and the same as the factory version.
I know they are standard on the 09 Escape xlt, not sure when they started that. I wouldn't let it break your deal , as you can just add it as an accessory without much fuss.
Old 04-10-2009, 06:26 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Good thing about the accessory adhesive mount pads is that you can mount them anywhere on the vehicle that you wish. If your Escape is an equipment hauler you could mount it on the hatch, like beside the license plate.
Old 04-10-2009, 07:00 PM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
alchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to behold
Good thing they have keyless entry - our '05 doesn't have a keyhole on the passenger or hatch door. Only way in with a key is the driver's door. Dumb.....
Thomas Paine: ...arms...discourage and keep the invader and plunderer in awe, and preserve order in the world as well as property. ...Horrid mischief would ensue were (the law-abiding) deprived the use of them.
Old 04-10-2009, 09:27 PM
Thanks! What a neat add-on, and cheap to!
Keyless Entry Question Aaron_Jones Excursion - King of SUVs 14 04-02-2016 02:39 PM
Aftermarket keyless entry 2002exPSD Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 02-13-2016 10:35 AM
Keyless Entry Code driverman1 Crossovers 0 11-09-2013 01:00 AM
08 escape keyless entry code polarisman Escape & Escape Hybrid 4 08-17-2012 05:13 PM
How can I tell if my truck came with keyless entry remotes? viperbluelx 1999 to 2016 Super Duty 4 05-31-2007 09:06 AM
Tags
2003, 2007, battery, door, drivers, entry, escape, external, find, ford, keyless, keypad, pads, standard, vehicles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
