what tires should i go with? - Ford Truck Enthusiasts Forums
Old 04-09-2009, 07:10 PM
phatt_boy phatt_boy is offline
phatt_boy is starting off with a positive reputation.
i have a 98 4x4 f150 with a 4in life on it i like to go play in the mud on the weekends but it is also my daily driver and so i am looking at either the BFGoodrich all terrain t/a k/o or the nitto terra grappler
i am just looking for some feedback on what yall think and have had good luck with thanks!
Old 04-09-2009, 08:21 PM
WeWonIt's Avatar
WeWonIt WeWonIt is offline
WeWonIt is starting off with a positive reputation.
My Terra Grapplers do well in the mud and on the road. Now mind you they are no Bogger, if you like to play in the real nasty stuff you might want to look into a real mud tire. Mine have done well in Alabama red mud, sand and tilled up pasture land and have great highway manners.
Old 04-09-2009, 09:21 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
try the pitbulls
-cutts-
Old 04-09-2009, 09:29 PM
hotrodkid13's Avatar
hotrodkid13 hotrodkid13 is offline
hotrodkid13 is starting off with a positive reputation.
getcha some tsl radials, all the self cleaning power of the original tsl, but with better road manners still whine like an sob, but last longer.
Old 04-09-2009, 09:47 PM
todder53's Avatar
todder53 todder53 is offline
todder53 is starting off with a positive reputation.
Look at the Mickey Thompson ATZ they have a great tread pattern but good for the road. Also the Pro Comp Xtreme All Terrain very aggressive tread pattern but great on the road.
Old 04-09-2009, 11:19 PM
how is the tread life on nitto terra graplers?
Old 04-10-2009, 12:23 AM
todder53's Avatar
I have heard very good things about them. Check out this link.
Error - Discount Tire
Old 04-10-2009, 01:01 AM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
I've got Nitto Terra grapplers (285 75) on the back of my 88 and so far they've done pretty good in light-medium mud, but the first time I got in some deep black clay they got clogged (but texas black clay can clog a bogger if ya tried hard enough) and ended all forward moment, but at least they didn't dig straight down with no moment like some tires do, so it was easy to get pulled out.
Old 04-10-2009, 07:58 AM
WeWonIt's Avatar
Quote:
I have 15,000 on mine and they still look new. My cousin said he got 45,000 out of them, but I expect 30-35K on a truck as big as mine.
Old 04-11-2009, 03:41 PM
Prozon's Avatar
Prozon Prozon is offline
Prozon has a good reputation on FTE.Prozon has a good reputation on FTE.
I was running the BFG All Terrain K/O's, they worked pretty good for light wheeling. But when I stepped up I put on Super Swamper SSR's.
They're both decent for pavement/mud. The All Terrains won't handle up to the really bad stuff though.
Old 04-12-2009, 01:13 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
i don't like my bfg a/ts they clog up pretty quickly and are hard to clear with sticky stuff they have more road noise than a regular tire though but not as much as a bogger
Old 04-13-2009, 11:56 AM
oldirtytruck's Avatar
oldirtytruck oldirtytruck is offline
oldirtytruck is starting off with a positive reputation.
I have 35 Pro Comp X-treme A/T's and they have been a great tire for road/sand/mud they are have wide gaps and are quiet.
Old 04-13-2009, 03:08 PM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is gaining momentum as a positive member of FTE.TheTinian is gaining momentum as a positive member of FTE.
Quote:
x2. If you mud every weekend, you will get tired of AT's. TSL's are great tires, and i think they whine even more than the Bias.... atleast mine do.
Old 04-14-2009, 12:19 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
im goin with the TSL radial ive seen many reviews and comments and i know a guy who runs them and so far he absolutely loves them he had boggers but he needed longer tread life he says they are comparable to the bogger in most types of mud but 10x better on the highway and they are better on sideways slopes as they have a good center lug pattern and the boggers dont....on my truck i have 31 pro comp m/ts and they are good highway tire some noise but i wouldnt recommend them for a truck that sees alot of mud they dont clean well and bogg down bad ive heard the pro compe x-treme series m/ts are decent
Old 04-14-2009, 12:07 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
Bfg at ftw!!!!!!!1111
My '03, 7.3 XLT supercab build thread socuban 1999 - 2003 7.3L Power Stroke Diesel 91 06-21-2016 06:54 PM
2 trucks 2 questions BLACKHAWK_1989 1987 - 1996 F150 & Larger F-Series Trucks 17 04-08-2015 04:07 PM
What am I looking for Elliot Ness Excursion - King of SUVs 6 04-25-2014 04:58 PM
2005 Ford Escape CEL P0171 P0174 daisyq31 Escape & Escape Hybrid 0 05-08-2013 11:25 AM
Introduction/About you thread, 20 simple questions. BlueOvalDismantlers 1973 - 1979 F-100 & Larger F-Series Trucks 46 10-15-2012 08:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
