2002 F250 rear rotors. Pull the axel shaft?
I need to replace the rotors on my 2002 F250. I'm told that they do not pop off like the front and that I need to pull the axle shaft. Is this true? Anyone know where to find pictures of this process? I have this...
3.Remove the axle shaft retaining bolts and remove the axle shaft.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
4.Using a suitable hub socket, loosen and remove the hub socket. (my note – they my mean to say the hub bolt?)<o></o>
5.Remove the outer wheel bearing<o></o>
6.Remove the hub and rotor<o></o>
7.Remove the rotor to hub bolts and separate the bug and rear disc brake rotor
<o>Thanks! </o>
<o>Thanks! </o>
bismic
08-10-2015 10:35 AM
redman84
17
05-29-2013 12:38 PM
