cruise control problems
G-day people its Ando here from Down under Perth Australia ,i have got a dual cab F-250 love it to death, but she is playing up on the long trips my cruise control engages the green light comes on and then at different time periods it drops out and the cruise control shuts off, now down here in perth we lack good f-truck mechanics so as you can imagine iam having trouble finding the info i need so iam sure out there in f-truck land someone must have had this happen to them as well ,so if anyone has any ideas it will be muchly appreiciated good on ya veiwers and take care out there regards Ando.
What year is it? there was an issue with the brake pressure sensor in the master cylinder. If the sensor is shorting out it will kick the cruise control off. The same could be with the brake pedal switch. The vss should be able to do it as well, if it goes out of the cruise control's adjustable range, but you see an ABS light the speedometer acting up if it was failing.
I think 99-05 had a twitchy brake pressure sensor that would fail and leak. Leaking from the pressure port could cause your brakes to feel mushy, I would definitely replace it if your in doubt, as it caused a few trucks to burn to the ground. This could also trip the ABS light.
Mate thanks very much for the info that is definetly what it is ive noticed a strong burning smell comming from the rear brakes so i think you have nailed guys thanks alot this is an awsome sight ive got three other mates i will tell to join up as well they have f-trucks to thanks again regards Ando.
divinusmonstrum
27
04-17-2013 11:13 PM
Ando5O
05-17-2003 04:23 AM
