Disable keyless entry pad - Ford Truck Enthusiasts Forums
Old 04-08-2009, 10:49 PM
fordor fordor is offline
fordor is starting off with a positive reputation.
How can I disable the keyless entry pad on my 05 SCREW without effecting anything else?? I researched it on this sight but can't find anything like that.
Thanks,
Bob L.
Old 04-08-2009, 10:51 PM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is gaining momentum as a positive member of FTE.
You can try and unplug it in the door. Take the door panel off and take a look, if its in there unplug it and see what happens. Hope this helps!
Old 04-09-2009, 05:22 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
I thought there was an option in the Owners manual
but yeah, just unplug it from the pigtail inside the door panel if all else fails
why do you want to disable it?
Old 04-09-2009, 07:52 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Have you got an Ex who knows the code?
Keyless entry key pad procedure
1. Turn the ignition to the 1 (OFF/LOCK) position.
2. Close all the doors.
3. Enter 5–digit entry code
4. Press and hold the 7 • 8. While holding the 7 • 8 press the 3 • 4.
5. Release the 3 • 4.
6. Release the 7 • 8.
The user should receive a horn chirp to indicate the system has been
disabled or a chirp followed by a honk to indicate the system has been
enabled.
Old 04-09-2009, 07:58 PM
Tylus's Avatar
if someone knows the code, reset the code to something else. unless that person knows the factory preset code...which sucks
Old 04-11-2009, 07:47 PM
Thats the problem. Someone knows the factory setting. Shorebird, Is that to disable the factory code??
Old 04-11-2009, 09:42 PM
shorebird's Avatar
From reading the manual it appears so. Try the steps and when you hear it just chirp without the honk it should be disabled. Maybe you could find another module with its code in a parts yard and install it.
Old 04-12-2009, 12:57 AM
Hummah Zach's Avatar
Hummah Zach Hummah Zach is offline
Hummah Zach is starting off with a positive reputation.
maybe you could unplug something from the module? its located on the back wall behind the seat and insulation
Old 04-15-2009, 06:30 PM
jgc2521 jgc2521 is offline
jgc2521 is starting off with a positive reputation.
Hey, i'm looking for a keypad. If you would wantto i would trade you for your door handle and keypad. just pm me
Old 04-15-2009, 09:10 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
Correct me if I'm wrong, but I believe the factory code is stored in the PCM and is VIN locked. If so, changing the key pad won't help. Possibly could get a new code flashed in from Ford at a dealer. Or just unplug it for now.
Greg B
Old 08-10-2009, 07:05 PM
imprezdcrew imprezdcrew is offline
imprezdcrew is starting off with a positive reputation.
anyone ever come up with a permanent solution to this problem?
Old 08-10-2009, 07:59 PM
Tylus's Avatar
you have 2 options
1. replace the lock module on the back wall of the cab...but that may be VIN locked and require Ford Tech PCM voodoo
2. unplug/replace the keypad on the door with a non-keypad setup
Old 08-10-2009, 08:01 PM
none keypad setup or non wired setup?
Old 08-10-2009, 08:08 PM
Tylus's Avatar
buy a plastic surround for the door handle that doesn't have the cutouts. just unplug the pigtail from the original pad and wrap it with some electrical tape to prevent a short.
all of the door handles interchange, so it's a relatively painless process
Old 08-10-2009, 08:10 PM
i see... i'm trying to keep the key pad though... but thanks
Key pads racin 1997 - 2003 F150 3 03-13-2016 09:59 PM
Keyless entry door pad. 260karl 1999 to 2016 Super Duty 1 09-02-2015 06:32 AM
X-wife !! THaywood 1999 to 2016 Super Duty 18 09-12-2012 07:16 AM
keypad keyless entry ogbobbyjohnson 1997 - 2003 F150 1 02-11-2012 10:47 PM
Remote keyless entry 61 uni 1999 - 2003 7.3L Power Stroke Diesel 5 12-30-2008 09:11 AM
Tags
2009, code, deactivate, deactivating, digit, disable, disablekeylessentryfordedge, entry, expedition, factory, ford, keyless, location, pad, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
