5.4 freeze plugs
Old 04-08-2009, 06:49 PM
On_Final's Avatar
On_Final
On_Final is offline
5.4 freeze plugs
My 2001 5.4 Triton 1/2 ton 4X4 froze.
I replaced the two outside freeze plugs. When I add water, the water goes straight to the oil Pan. Am I missing some plugs somewhere?
Old 04-08-2009, 08:01 PM
eightrac's Avatar
eightrac
eightrac is offline
Your block and/or heads are cracked.
Old 04-09-2009, 01:06 PM
l-m tech's Avatar
l-m tech
l-m tech is offline
There are 4 freeze plugs behind the timing cover.the bottom 2 usually rote out from debrise that dosnt get circulated .
Old 04-15-2009, 03:52 PM
On_Final's Avatar
On_Final
On_Final is offline
freeze plugs
Thanks so much!
I removed the timing cover to find 2 freeze plugs popped out. I have replaced them and all is well.
I had two mechanic shops tell me the motor was shot after they replaced the freeze plugs behind the motor mounts.
Old 04-16-2009, 09:54 AM
eightrac's Avatar
eightrac
eightrac is offline
Damn! I forgot about those!
Old 04-16-2009, 05:03 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Originally Posted by On_Final
Thanks so much!
Wow, learn something new everyday
Rep points for that one.
Old 02-27-2017, 11:34 AM
Bajajrv's Avatar
Bajajrv
Bajajrv is offline
Does anybody knows was size freeze plugs a 5.4 engine gets and how many
Old 02-27-2017, 11:35 AM
Bajajrv's Avatar
Bajajrv
Bajajrv is offline
Freeze plugs
Does anybody knows how many and what size freeze plugs a 5.4 engine gets
Old 02-18-2020, 03:30 PM
Jr Hamilton's Avatar
Jr Hamilton
Jr Hamilton is offline
Where are the freeze plugs at the back of the 5.4 L Triton? Or am I wrong thinking there are a couple. My coolant is leaking where the trans bolts onto the block. At least thats where it looks like. and on the bottom side. Please help me if you can
Old 02-18-2020, 07:33 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
You wont be able to see them with the tranny in place, you are going to need to remove the tranny. But it sounds more like either your heater core line fittings are leaking (common) or the coolant tube that runs in the engine valley is leaking (very common). Look below the intake manifold for pooled up coolant.
351WTF
1999 to 2016 Super Duty
08-25-2017 07:31 PM
351WTF
Modular V8 (4.6L, 5.4L)
08-25-2017 12:30 PM
Spaznaut
07-11-2017 09:22 PM
fishfreak101
02-10-2017 04:27 PM
Tparkin99
13
01-29-2017 02:35 AM
Quick Reply: 5.4 freeze plugs
