5.4 freeze plugs - Ford Truck Enthusiasts Forums
5.4 freeze plugs
Old 04-08-2009, 07:49 PM
On_Final On_Final is offline
On_Final is starting off with a positive reputation.
5.4 freeze plugs
My 2001 5.4 Triton 1/2 ton 4X4 froze.
I replaced the two outside freeze plugs. When I add water, the water goes straight to the oil Pan. Am I missing some plugs somewhere?
Old 04-08-2009, 09:01 PM
eightrac eightrac is offline
eightrac is starting off with a positive reputation.
Your block and/or heads are cracked.
Old 04-09-2009, 02:06 PM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
There are 4 freeze plugs behind the timing cover.the bottom 2 usually rote out from debrise that dosnt get circulated .
Old 04-15-2009, 04:52 PM
freeze plugs
Thanks so much!
I removed the timing cover to find 2 freeze plugs popped out. I have replaced them and all is well.
I had two mechanic shops tell me the motor was shot after they replaced the freeze plugs behind the motor mounts.
Old 04-16-2009, 10:54 AM
Damn! I forgot about those!
Old 04-16-2009, 06:03 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
Originally Posted by On_Final View Post
Thanks so much!
Wow, learn something new everyday
Rep points for that one.
Non-freeze plug block heater khxor 1999 to 2016 Super Duty 12 12-09-2015 11:08 AM
1994 5.8l freeze plugs Bigjim94 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 09-05-2013 01:58 PM
How to replace freeze plugs? (1986) neumayr83 Ranger & B-Series 4 06-26-2011 09:11 PM
water in oil, front freeze plugs? HomeRx 1997 - 2003 F150 2 02-09-2011 08:35 AM
5.4l Anti-freeze change motown 1999 to 2016 Super Duty 2 10-25-2010 09:52 PM
Tags
150, 2001, 2002, 54, block, core, engine, expedition, ford, freeze, location, motor, plug, plugs, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
