Best size tire with heaviest load range for 1989 F-350 SW
Hey how about this bud, Tire Specs for General Grabber AT 2
this tire right here, is a load range E and has a weight of 3000 pounds at 80 PSI, so multiply that by 4 since your truck has 4 tires, and you get a grand total of 12,000 pounds, and thats more then enough for your truck.
I have Fire Stone Destinations on my truck, 285/75/R16, and they have a load range rating of E, and hold 3715 per tire, times 4, thats 14800 pounds, once again more then plenty of weight.
I have a 89 F350 SRW Crew Cab with a 9 1/2 ft lance camper and I tow a race car also. I have Dick Cepek FC2 Tires 285/75/16 load range D. I have put over 10,000 miles on it in the past 2 years and have never had a problem. The main thing is to keep the tires inflated to the correct pressure.
i run 305/70/16 lt load e ,good year silent armor's , on my f250 leafed 150 ,no helpers and no issues i lvoe these tires , my truck is lifted 4 inch as well and i use a weight dist hitch on my 29 ft camper trailer. 351 e4od w/3.73 gears . i do fine . the 87 shasta i tow is 4550lb dry . usually with the 40 gallon fresh water tank full as well and food and gear and stuff in the truck bed . yes i realize i am like at the limit of what the trucks frame and 8.8 can handle, but its girdled as well .everything is beefy on it .
jtharvey
52
07-28-2006 03:19 AM
