1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
'95 F700 Runs Rough
Old 04-08-2009, 06:11 AM
SearsGuyInLa's Avatar
SearsGuyInLa
SearsGuyInLa is offline
'95 F700 Runs Rough
My buddy has this '95 F700 Uhaul truck that runs terribly. It seems to have a misfire (spits and sputters cold or hot) and will not stay running. It has (2) Ford diagnostic ports under the passenger dash and when I connect SnapOn Solus, it has no codes. New distributor, plugs, wires, (8) injectors, egr and dpfe, and fuel pump all installed by Uhaul. He said it ran great for 30 minutes after he drove off then started missing again. Uhaul can't get it right so I want to help if I can. It's hard finding diagrams/diagnostic charts for this 7.0 V8. If anyone has a good place to start it would be very nice from the Ford gods.
Old 04-09-2009, 12:55 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Feel free to bump this every day or two, so it gets a lot of coverage.
Interesting problem.
Old 04-09-2009, 02:26 PM
Downriver Thunder's Avatar
Downriver Thunder
Downriver Thunder is offline
You clean the MAF sensor?
Old 04-10-2009, 06:25 AM
SearsGuyInLa
I can not seem to find a mass air flow meter. If there is one, it is hiding good. I did find that clinders #7 and #8 are about 10 psi lower than the other 6 on cylinder compression. Also, this has a governor mounted on top of the throttle body. thanks to everyone for the help so far.
Old 04-10-2009, 12:04 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Any chance the temp sensor(s) are bad?
It might not have a MAF - I dunno.
Hang on, I'm going to try to get a Ford guy in here.
Old 04-10-2009, 07:17 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Quote from PowerStrokeHD:
"The 7.0L has a MPI speed density fuel injection system, so there is no MAF.
A quick look shows that he should be seeing 40 psi at the pressure relief valve located on the right bank of the fuel injection supply manifold."
Old 04-11-2009, 12:23 AM
SearsGuyInLa
Wow I think i'm getting somewhere with this truck finally!!! First off, I checked the coolant temp sensor by removing it. the end of the sensor was GONE (rusted away I guess) so I replaced it. Also, #8 fuel injector was wet with gas around the base. Replaced that injector and truck runs like a new one. Thanks ya'll!!!
Old 04-11-2009, 11:09 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Rep points for reporting back!
Glad you found the problem.
Old 04-11-2009, 04:42 PM
SearsGuyInLa
Thanks a lot for steering me in the right direction. Now i'm wonderin where the end of this coolant temp sensor went and if it's going to give me troubles.
Old 04-11-2009, 07:10 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
If it went anywhere, it's laying in the radiator on the supply side.
I'm assuming the temp sensor was in the intake near the thermostat? If so, it went through the thermostat, and into the radiator. Probably not a problem.
Old 04-11-2009, 08:41 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Another FTE success!
DedicatedLuzer
Large Truck
03-01-2023 05:34 PM
thewheelman
2015 - 2020 F150
09-06-2017 07:47 PM
79-ford-f150
09-20-2016 09:24 PM
Sharynf
Large Truck
01-26-2016 06:25 AM
Shenna Tipton
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-22-2015 12:19 AM
Quick Reply: '95 F700 Runs Rough
