Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 04-10-2009, 06:06 PM
Konarain Konarain is offline
Konarain is starting off with a positive reputation.
Wink
I love diving under my F-250! It is becoming my best friend!
Just like the Kona Latte I'm going to go for now..after I put in some $3.00 gas! I've been withput transport for over a year, and I love my truck!
  #32 (permalink)
Old 04-10-2009, 06:48 PM
18wheelin 18wheelin is offline
18wheelin is starting off with a positive reputation.
OK, here are the pics of how I change the oil filter from the top.
Using a 10mm wrench, remove the bolt that holds the air intake in place.
Intake picture by 18wheelin - Photobucket
Next, pull the air intake out of the black box that contains the air filter and swing it out of the way.
Intake Off picture by 18wheelin - Photobucket
Now you have a clear view of the oil filter and access to it.
Oil Filter picture by 18wheelin - Photobucket
Just kneel on the front bumper and lean over the radiator and you will be able to reach the oil filter with a strap type oil filter wrench.
Filter Wrench picture by 18wheelin - Photobucket
Kneeling picture by 18wheelin - Photobucket
Wrench on Filter picture by 18wheelin - Photobucket
Loosen the filter with the wrench and then remove it by hand. You will have almost no mess. They don't come much easier than this.
  #33 (permalink)
Old 04-10-2009, 07:09 PM
spatts spatts is offline
spatts is starting off with a positive reputation.
I now can see why you would change the oil filter from the top on a (4x2) much lower to the ground. But the (4x4) is high enough to get under with out jacking up . "To Each His Own" The important thing is that the oil & Filter is getting changed
__________________
2005 F-150 SCREW
  #34 (permalink)
Old 04-11-2009, 12:43 AM
Quote:
It has nothing to do with the ground clearance. I was laying under the truck on my first attempt to change the filter. There is too much stuff in the way to loosen the oil filter with my strap wrench from the bottom, so I decided to go at it from the top. It proved to be very easy and very clean. I would change it the same way on a 4x4 if I had one.
  #35 (permalink)
Old 04-11-2009, 01:31 AM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
a properly installed oil filter should only be hand tight
you lightly oil the gasket, then run the filter up until you get contact. then continue past that point 1/2 an additional turn...and this is all BY HAND
using a wrench to install a filter only overtightens the filter and squashes the gasket...you should only need a wrench to remove the filter if it's the very first time the oil has ever been changed (Factory puts the filter on with a dry gasket...very big PITA to remove)
btw, my the top of my radiator shroud is almost chest high on me...and I'm 6'3"...there ain't no way I'm going from the top. the bottom is easily accessible.
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
  #36 (permalink)
Old 04-11-2009, 10:12 PM
baitmaster baitmaster is offline
baitmaster is starting off with a positive reputation.
All oil filters look pretty much alike, how hard could it be to find... on any vehicle? You will also want to know where the oil pan drain plug is too. Get that manual.
  #37 (permalink)
Old 04-13-2009, 11:30 AM
rcaddell rcaddell is offline
rcaddell is starting off with a positive reputation.
I have an FX4 and go from the top as I get better grip on the filter. I also tighten by hand.
  #38 (permalink)
Old 11-01-2009, 03:03 PM
gfwelsh gfwelsh is offline
gfwelsh is starting off with a positive reputation.
18Wheelin', it's posts like yours that make this one outstanding place on the web. Thanks!
  #39 (permalink)
Old 11-02-2009, 04:53 PM
Quote:
After I accidentally drained the Trans fluid my friend said, "The oil pan is between the wheels!"
  #40 (permalink)
Old 11-02-2009, 08:23 PM
phillips91 phillips91 is offline
phillips91 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by damone View Post
While we are on the subjetc of oil filters, how canone be removed w/o dripping oil all over the place.
When I change mine I just take a screwdriver and poke a hole in the bottom of the filter and let it drain.
  #41 (permalink)
Old 11-02-2009, 10:17 PM
jsoko's Avatar
jsoko jsoko is offline
jsoko is starting off with a positive reputation.
Quote:
WHAT kind of CAR was it
__________________
"For those who have fought for it, Freedom has a taste the protected will never know"
'06 F150 4x4 5.4 XLT SB EXT CAB BLACK
'77 F100 RANGER XLT 392 STROKER CHEVY & HEMI SMOKER
  #42 (permalink)
Old 11-03-2009, 10:54 PM
stronger stronger is offline
stronger is starting off with a positive reputation.
I was all about poking fun at 18Wheelin' as well, then I seen the pic of his dog in the drivers seat. That was Great. Top. Bottom. Either way gets it done. like she said. lol.
  #43 (permalink)
Old 11-09-2009, 02:59 PM
Ford Truck! I've since changed the oil and used Mobile 1. Can't reach the filter from the top on a super duty, But it was no problem! Thanks guys! Aloha
  #44 (permalink)
Old 11-09-2009, 04:01 PM
Off topic.....but if I send you some money could you mail me a couple of burgers from Lulu's??
  #45 (permalink)
Old 11-10-2009, 09:59 PM
90taz 90taz is offline
90taz is starting off with a positive reputation.
use a wrench with a handle that swivels. placed your driain pan under the front cross member, the oil will hit the plastic catch pan and drain mostly towards the back. dont dump all of the oil out of the filter until you pull it down. this takes every bit of two minutes.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
