egr delete 2005 6.0 - Ford Truck Enthusiasts Forums
egr delete 2005 6.0
Old 04-08-2009, 01:19 AM
ford4x4956's Avatar
ford4x4956 ford4x4956 is offline
ford4x4956 is starting off with a positive reputation.
egr delete 2005 6.0
been reading and decided the best thing to do is delete or bypass the egr POS stuff....should i just block it off or should i delete the whole thing??? its an 2005 6.0....im planning on doing it myself...thanx
Old 04-08-2009, 06:09 PM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
HeavyAssault is gaining momentum as a positive member of FTE.HeavyAssault is gaining momentum as a positive member of FTE.
A modded up-pipe is easily done by yourself and doesn't cost a whole bunch. The full delete can be done being extensive and costly but well worth the effort.
Google FIRST COAST DIESEL PERFORMANCE
Old 04-08-2009, 07:10 PM
ford4x4956's Avatar
so to bypass it should i just plug the up pipe?
Old 04-08-2009, 11:25 PM
Black1 Black1 is offline
Black1 is gaining momentum as a positive member of FTE.
Quote:
That would still allow it to put coolant in the intake when the core fails. To get it to the point you can block off the EGR cooler-to-intake manifold junction, you'll basically have it out of the truck and in your hands anyway.
My only regret with deleting the EGR cooler is that I didn't do it sooner. It is not inexpensive to do, but after finding my exhaust full of coolant I was afraid I'd cost myself even more by pushing my luck. BTW, did you know the exhaust manifold holds enough coolant to nearly fill a 1lb coffee can? That's how much I sucked out of mine with momma's (former) turkey baster.
I gotta remember to run by the store and get her a new turkey baster before she realizes it's missing.
Old 04-09-2009, 12:14 AM
scameron scameron is offline
scameron is starting off with a positive reputation.
when the cooler failed on my 05, i took it as an opportunity to rid my truck of the system. plus, a new cooler was pretty much the same price as a new SCT X3 with custom tunes. lucky for me i have a friend with a custom metal fabricating shop. had the scope and elbow cut off the up pipe and a patch welded on. took my cooler and had him perform what is known as the crack pipe mod. do some searching on this site. you will find a couple guys who did this delete for less then 100 bucks. the cost of those delete kits are not justified. problem i have after the delete is that my turbo seems to have gone into what is refered to as EPA or Limp mode. my boost is limited to 20psi. this can be taken care with a custom tune.
Old 04-09-2009, 02:21 AM
adambomb's Avatar
adambomb adambomb is offline
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
how effective is the "crack pipe" mod if you don't cut out the scoop in the up pipe?
i know it still eliminates the whole cooler, but if you leave the scoop are there and downsides?
i'm thinking it just won't be as free flowing?
thx
Old 04-09-2009, 09:33 AM
thx
i hear the scope affects flow of exhaust. cut it out or buy an up pipe already modified.
Old 04-09-2009, 01:29 PM
hangon2me hangon2me is offline
hangon2me is starting off with a positive reputation.
I have done the Blocker Plate with the Turbo up-pipe, everything looks stock.
As for the EGR cooler, I have never heard of the EGR cooler EVER failing after it has been blocked. You need to remove the up-scoop from the exhaust for best performance.
Old 04-09-2009, 03:27 PM
Quote:
I haven't either. To be fair, I've never heard anyone say their failed cooler filled the passenger-side exhaust with coolant all the way up to the up-pipe/cooler juncture, either, and I sure as he11 experienced it myself. I had coolant in the intake, but thankfully it was not filled.
After experiencing what I consider a complete failure, I can't in good conscience recommend anything but a total delete/trashbin solution to the EGR idiocracy on these motors. In no way shape or form is that thing doing you any favors bolted to your motor.
If anyone needs an '04 up-pipe (no scoop inside) you can have my old one for the price of shipping. If you just want to do a block-off it'd be easier than grinding the scoop out of an '05 or later.
Old 04-09-2009, 10:53 PM
woodys06 woodys06 is offline
woodys06 is starting off with a positive reputation.
Doing the Elite diesel delete this weekend. Cant think of a better way to spend Easter.....
Old 04-10-2009, 08:03 AM
As long as your EGR cooler isn't currently ruptured you can mod the up-pipe (plug and cut out the scoop-if present).
As you can see with the other posts the if you don't have issues you could get by with just a modded pipe. You have decreased the chances of an EGR cooler rupture.
If you have EGR cooler issues, the full delete is the better choice. All those pieces need to come out so just trash the OEM junk, and fix the problem once and for all.
Egr valve delete Shawn93 6.0L Power Stroke Diesel 3 06-17-2015 01:59 PM
has my EGR been deleted? cocoabeach_steve 6.0L Power Stroke Diesel 11 04-11-2014 10:32 PM
delete or bullet proof the EGR? USCG_PA Excursion - King of SUVs 14 03-02-2014 02:58 PM
STEALTH DELETE AND TUNE winklershop 6.0L Power Stroke Diesel 7 01-15-2014 01:16 PM
how many miles on your stock 6.0 bfloyd4445 1999 to 2016 Super Duty 45 07-25-2011 04:32 PM
Tags
2005, 60, cracked, delet, delete, egr, ford, forums, mod, pipe, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
