Fords new 5.0 coyoty!!!!
Yeah, that is what I am seeing for the biggest use of VVT, is idle quality with more aggressive cams and emissions. The VVT actuator in the dodge viper has something like 45* of rotation, but dodge only uses about 38* of it however.
I am kind of surprised that a hand held scanner would have the ability to adjust the cam phasing, or let alone the computer on the car had the ability for something to adjust timing manually on the fly.
Why couldn't you? You can change almost every part of a computer controlled car system with a NGS.
Also, anyone who thinks that over-head cams makes an engine magically more powerful then a pushrod engine knows little to nothing about engines.
I'm saying, I can see reflashing the computer, and manually locking the cam phasing, but the ability to adjust on the fly without any aftermarket PCM programming just surprised me.
GM and Chrysler engineers sat down and with a clean sheet of paper and performance in mind, they decided on pushrod V8s.
Depends. If physical engine size is an issue, then OHV for sure. Want to keep the over all valve train simpler, OHV as well. If i want leeway to bring the revs up, then OHC. If overall engine size and cost and complexity is not a problem, then sure lets stay high tech (sarcasm) and go OHC.
From what I've read, variable valve timing is more or less for emissions, idle quality and retaining some low end torque. Variable timing on the exhaust side can help you maintain better idle quality on bigger cams, as well as provide an EGR-like effect. Variable timing on the intake side can help with low end torque.
Now if it was like honda'a V-TEC that actually has two profiles on the camshaft, you could do some interesting things. One profile that favors low end torque, for launches and powering out of corners without downshifting, and another profile that likes high-end power for when you get the revs up on the straight away
SOHC and DOHC will allow higher RPM with better valve control. No more bent pushrods and less likely to float valves.
Not sure GM and Mopar started wtih a clean sheet of paper for their motors. It looks like a lot of cost cutting by limitling retooling costs.
But that's a moot point anyways, since GM and Chrysler are both making tons of power N/A with their 2 valve heads.
Likewise for the Hemi, it shares nothing in common with the 318/360 LA series engines.
SuperTruckUSA
Vendor Specials, Discounts, Product Announcements & Group Buys
01-14-2016 03:51 PM
offroadnt
06-07-2011 10:01 PM
rambaseball45
5.0L Coyote
45
08-27-2010 06:58 PM
