Vent window help
I'll be darned, it must be riveted in... good catch!
eBay item #140312149176
eBay Motors: 49 50 51 52 Ford truck lower vent pivot-NOS-1949 1952 (item 140312149176 end time May-04-09 05:38:42 PDT)
I do not know if this is the same parts as 1949/52.
This is considered a body part, and the catalog that covers 1944/52 body parts is very hard to find.
Carpenter doesn't have these parts listed in his catalog.
There's nothing magic about the spring, other than it's pretty stiff, and it can't be over a certain diameter and still get thru the window frame into the door. Do you have the other one? True Value here has a good selection of springs that could be cut down. The washer is so the end of the spring doesn't hang up on the frame. A nylock nut would be best. I have a decent picture if you need it.
I could try the hardware store, just trying to keep it correct. Does anyone know if the kit for the newer years would work? Who sells them to look at? Please bare with me this is for a buddy and I haven't seen the peice yet. Just beibg told what he needs.
Well, you'll need more than just a spring and a nut. The upper washer that goes on the shaft but inside the "loop" under the frame is tear drop shaped and has a square hole in it. That's what prevents you from opening the window two far. Then in progression downward, there is a slip (thin and wide) washer, the spring, another slip wahers, then a regular cut washer and a castleated locking nut.
I'm not sure what the kits include, but in the drawings of the various vent windows the pieces and th enumber of pieces are different. I'll do a little more research and get back to you. Mine are currently out of the truck so I can get some good photo's for you as well.
