Vent window help
Old 03-03-2010, 08:58 PM
needhelp49's Avatar
needhelp49
needhelp49 is offline
thanks ill just put them in the dumpster with the rest of the stuff
  #32
Old 03-03-2010, 09:34 PM
tip49's Avatar
tip49
tip49 is offline
Vent windows
I did get spare parts this week, just wanted to re-enforce the proper install as posted by Julie.
In hind sight I wouldn't throw any thing away again, these parts are harder and harder to come by. I don't how I would have managed to install vent windows if I hadn't found the frames at a wrecker.
Always someone looking for a rare piece to complete their project.
Tom
  #33
Old 03-05-2010, 08:47 AM
needhelp49's Avatar
needhelp49
heres a pic of the way thay should be i have 6 vent windows from 3 diff trucks every one of them is this way so makes me belive its the right way
i can take it apart and take pic of the parts in order if someone wants i need to anyway
  #34
Old 03-05-2010, 09:00 AM
needhelp49's Avatar
needhelp49
it only toke a couple secs to take it apart so heres the order the screw driver would be were the frame is
  #35
Old 03-05-2010, 10:10 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Yours had a washer between the window stop and the frame in the upper half. Mine had one on both sides of the frame - that's the "Extra" washer I called out in Post #16 above.
However oddly, the body parts catalogue only calls out one of the two. On yours it was assembled above the frame, I reassembled mine below the frame to act as a bushing for the spring pressure and deleted the additional washer - works very smoothly.
  #36
Old 03-25-2010, 02:31 PM
tip49's Avatar
tip49
tip49 is offline
Glass installed
I installed glass into vent frames today; glass was slightly less deep as original so I used 3M adhesive moderately to ensure glass would not shift. the plywood jig was like a spare set of hands.
  #37
Old 03-26-2010, 01:48 AM
Julies Cool F1
Good thinking!
  #38
Old 03-26-2010, 11:31 AM
tip49's Avatar
tip49
tip49 is offline
Thanks
Thanks Julie; every now and then I get an Idea I can use.
It did make the install easier.
I got the frames completed but won't get to install them into the doors for a week; work getting in the way once again !
  #39
Old 03-26-2010, 11:36 AM
Julies Cool F1
Bad news is, we'll probably steal your idea! Gotta watch us all the time!
  #40
Old 06-11-2010, 07:38 PM
eddie201's Avatar
eddie201
eddie201 is offline
Originally Posted by Julies Cool F1
Well, you'll need more than just a spring and a nut. The upper washer that goes on the shaft but inside the "loop" under the frame is tear drop shaped and has a square hole in it. That's what prevents you from opening the window two far. Then in progression downward, there is a slip (thin and wide) washer, the spring, another slip wahers, then a regular cut washer and a castleated locking nut.
I'm not sure what the kits include, but in the drawings of the various vent windows the pieces and th enumber of pieces are different. I'll do a little more research and get back to you. Mine are currently out of the truck so I can get some good photo's for you as well.
Julie
Do you know where i might find vent window frames or pivits? 48 50 ford
  #41
Old 06-11-2010, 09:00 PM
Mervy49's Avatar
Mervy49
Mervy49 is offline
I'll be keepin' that in mind too, that's all coming up soon.
thanks....
Mervy
  #42
Old 06-12-2010, 02:03 AM
Julies Cool F1
Originally Posted by eddie201
Julie
The only difference between the 48-50 and 51/52 vent windows is the 51/52 has a locking button on the handle. These can be easily changed out and both styles (of handles) are available after market.
About once every month the pivot bolts show up on e-bay. Vent windows themselves show up there about once every three months.
I'd check on e-bay and look at guys who are selling lots of parts from a newly acquired parts truck. They may have a set but not have them listed.
There are two guys with trucks parting out selling stuff at the moment. One here in San Diego - it's a 51/2 panel I believe, and the other is a 48-50 in Kingman Ca. He parts out lots of these trucks. He has a couple hoods and some doors up for sale currently.
You may want to send a PM to "51 PanelMan" to ask if he has any at the moment.
  #43
Old 06-16-2010, 10:25 AM
Julies Cool F1
cashman2310
02-26-2016 04:46 PM
bphirt1
16
02-17-2016 08:54 PM
F4Bob
02-20-2015 01:07 AM
midsouth
04-13-2013 01:29 AM
TBucketJack
02-21-2005 09:35 PM
Quick Reply: Vent window help
