Size of alignment holes????
I am looking at replacing my fender badge emblems with a set of smoked led marker lights. Before I go and peel off my emblems, does anyone know how big and far apart the alignment holes are in the fender? I want to make sure my lights will cover the factory holes.
hope the photo's help. The holes are pretty far apart on the fenders.
Fender: the locator pins are centered horizontally, and on the extreme edges
Tailgate: 1 on the outer edge, the other is slightly past the midway point. the pin on the end is behind the "F", center pin is behind the "5"
Thanks Tylus....Just for the heck of it I went out and started peeling one off enough that I could stick it back on. Believe it or not there is a small hole towards the front of the truck that utilizes the small alignment pin that you showed me; But for some stupid reason, under the tape, there is a large whole about 3/4" round that is there but does not do anything. So between the big hole and small hole that is spaced about 5" apart, it really screws me because now I need a larger marker light than what I wanted.
