Magnaflow and SCT(DP Tune) Issues?
Old 04-06-2009, 03:08 PM
Jbru167's Avatar
Jbru167
Jbru167 is offline
I just installed a Magnaflow Turbo back with an SCT X3 (DP tuner) Econo tune on my 6.0 PSD. On cold starts I get a lot of blue/White smoke, for about 5 seconds and some sputtering,once its warm and I start it again later no smoke. I switched back to stock and also the SCT street tune one puff and nothing else for cold start nothing like the Econo tune. Any sugestions? Called Jody he is on Vacation.
Another thing I noticed with the Magnaflow was I can really hear the turbo which I expected but when I stand next to the exhaust tip there is a constant hissing sound is that normal? I only have about 50 miles on the exhaust.
Old 04-06-2009, 03:28 PM
ReAX's Avatar
ReAX
ReAX is offline
The whine can be expected with a very open exhaust. For the smoke color, blue usually means oil and white means coolant. Keep an eye on your oil and coolant levels until you get in touch with DP.
Unless you didn't reconnect something under the hood, I can't imagine swapping the exhaust out would cause an oil or coolant leak or running rich. So I suspect it's in the tune and you might need a slight tweak.
Whitson Metalworks
30
10-26-2015 08:27 AM
EPI-911
09-29-2015 05:16 PM
ReugularGuyBob
13
06-06-2015 03:53 PM
jeffdoerr
26
10-03-2009 01:32 AM
Chris89lx
04-28-2009 11:41 AM
Quick Reply: Magnaflow and SCT(DP Tune) Issues?
